Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite error message F 02
My kenmore elite washer is giving me an error message F 02 not draining
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
2 Suggested Answers
  • 949 Answers
SOURCE: Kenmore Elite error message F 02
Here is what the manufacture says about F02 - Below this are my comments
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
4. Check the drain pump filter for foreign objects.
5. Plug in2_bing.gif washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Phil's comments---->
If you washed a rug with a rubber backing or small articles like baby socks you may have a plugged up pump. To access the pump lay on the floor and remove the 3 screws holding the lower panel of washer on. Pull down and out on the panel to remove. Lay out a lot of towels under the unit, I mean a lot... Look in the center for a white cap about the diameter of a large cup, it will have a handle on it to turn, turn this left(counter clockwise) to unscrew. This will unscrew and pull out, but be careful when it comes out so does all the water. Clean out the trap that is in your hand and anything you see or feel in the sump area the trap came from. Reassemble and test. If this does not work you will more than likely need a new drain pump, that is the component on the right of that trap you just cleaned out.
Posted on Apr 20, 2010
Testimonial: "You are a Guru! Thank you so much for informing us about the "hidden" trap which housed an ankle sock, .90 & lint! works like a charm now!!"
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Error code f 02
    I think it's a slow drain fault. But would need full model number to say for sure. Still it wouldn't hurt to check the drain pump for crud. Here are some vids that might help. Don't worry too much about brand specifics. Many brands share identical and similar parts.
    http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
    Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
    I have a kenmore elite he 3 front load washer...im getting f error 02. it runs fine until the end of the cycle will not drain or spin.
    Hello & Welcome to FixYa
    F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
    Kevin
    May 22, 2011 | Kenmore Elite 45986 Front Load Washer
    With Kenmore Elite front load washer, what is F02 error?
    Hi
    Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
    • Check the drain hose and make sure it is not plugged or kinked.
    • Check the electrical connections at the pump and make sure the pump is running.
    • Check the drain pump filter for foreign objects.
    • If the above does not correct the problem, replace the pump.
    Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Aug 22, 2010 | Kenmore Elite 45986 Front Load Washer
    displayed.
    or kinked.
    Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
    My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
    "F/02" Long Drain
    NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
    Oct 24, 2009 | Kenmore Elite HE5t Washer
    Kenmore elite washer drain problem
    “F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
    Mar 23, 2009 | Kenmore Elite 45986 Front Load Washer
    Washer won't spin- flashing "f 02"
    in the HE3 series it means the drain tube or pump is clogged
    Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite
    f02 relates to a slolw drain during cycle, caused usually from debris caught inside pump assy, try removing the lower acess panel, youl lseeee hte pump right there upon removing panel , theres a screw type button trap you can remove to empty the debris, word of caution though before unsrewing be prepard with a plastic garbage bag cause it will empty wate rinside machine as well
    Apr 25, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    156 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
