Question about JBL ES150P Subwoofer Speaker
Transmitter loses signal and sub's sound is soft sometimes
I have a brand new ES150PW and the after about 2 minutes the transmitter and sub do not communicate. Also sometimes the sound is very low. I can toggle the crossover switch back and forth to make it louder again. Either I'm doing something wrong or I bought some bad equipment. Any advice?
4 Suggested Answers
SOURCE: JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Posted on Nov 08, 2008
SOURCE: JBL Sub 12 continues to make clicking noise
check the audio amplifiers of the sub
Posted on Jul 13, 2009
  • 308 Answers
SOURCE: JBL Subwoofer - Intermittent operation
Sometimes bad caps show a lifting or rounding of the top of the cap, sometimes this top will split from heat and pressure and sometimes it will not show any sign of damage but will be dry inside and its capacitance value will drop to a very low value. Replace the big power supply caps and test again. Get the same size, value and voltage rating. You can go higher on voltage rating and a bit on value. Getting a similar size or something that will fit in the same space is important also.
Posted on Mar 24, 2010
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory ยป FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
Model c87214. Why does it keep losing outdoor temp signal?
I have had that experience. You may have to repeat initial installation once more before concluding the system is n.g. Remove batteries from the indoor receiver. Review the instructions and verify transmitter was installed in correct location. Do this as you are removing transmitter batteries. For luck, install new batteries in the transmitter. At the receiver, reinstall batteries (or install new batteries). After approx. 10 min., you should see temperature displayed. My LaCrosse system has its wacky days, sometimes displaying no temperature or an abnormally high temperature when morning sun hits the transmitter. Also, successfully resetting is a once-in-a-blue-moon affair.
Dec 28, 2015 | Measuring Tools & Sensors
I bought an ft4 monitor in nov 2010 and when I am exersizing for approximately 20 minutes the monitor loses signal from the transmitter. I can sometimes get a signal back by pressing the transmitter strap...
Look in my tips and tricks page for the most common issues regarding Heart Rate transmission, if none of these fix it, then you "may" have an issue with the equipment itself. Generally the most common issues area:
Strap not on correctly (too loose, too low, upside down, not enough wetness to conduct)
Environmental factors (signal interference, etc)
Mar 25, 2011 | Polar Heart Rate Monitors
We just got a new Weather Channel wireless temperature sensor 9245. It seems that the transmitter isn't working. We followed the directions and put new batteries in the transmitter first, then the...
The new batteries could be defective or installed incorrectly. Remove all batteries and start over again. Be sure to let the transmitter initialize and begin sending data before you install the batteries in the receiver. If you can't receive a signal, the transmitter may have failed.
I have an Oregon Scientific receiver that is within line of sight of the transmitter and receives nothing......
May 17, 2017 | La Crosse Technology WS9245UBKITCBP...
Not enough Amp?
You should still get sound even with small amps but it would be rather weak. Check first the source of the signal. Test with different sources to be sure. Check for loose connections.
Oct 02, 2009 | Rockford Fosgate Punch 400W Class AB...
Jul 20, 2009 | JBL PB10 Subwoofer
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
Surround sound playback problem
1. do a hard reset to factory settings.
2. do a surround sound test to make sure all sounds are coming to all speakers properly
3. check the cable from the main unit to the sub for any obvious problems. ie. plugged in securely etc etc.
it sounds like the cable from the main unit to the sub is faulty
good luck
smeags.
Dec 31, 2007 | Zenith DVT312 System
JBL ES150P Subwoofer Speaker Logo
101 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
