Question about Cobra Two Way Radio
No transmitting and receiving. - Cobra Two Way Radio
    Scholar:
  • 157 Answers
A power supply problem. Check the fuses and power wiring connections.
Posted on May 14, 2010
Kenwood Protalk tk-3200U8P will receive, but not transmit. When talk button is push a loud beep will sound. Any suggestions?
Assuming it is programmed correctly, it is a weak, undercharged or bad battery. Transmit takes a lot more power than receive. A beep or no transmit, even if the Transmit light comes on can still mean the battery condition described.
Feb 11, 2015 | Kenwood Radio Communications
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
I am able to transmit but not receive
get another that only receives and no transmit.hook them up together .one on top of the other .I have a friend that did this and it actually worked
May 30, 2012 | Cobra 18 WX ST 40-Channels Base CB Radio
T5100 : One radio receive but not transmit back.
check batteries, maybe they are on the way out. otherwise its in the lever connection. old?
May 07, 2012 | Motorola Talkabout T5100 (14 Channels)...
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
Hisses/squeals when transmitting
Check the input voltage into the radio while in transmit. The voltage maybe dropping as you go into transmit which causes it to drop into receive. That in turn allows the voltage to come back up. With your finger still on the PTT it tries to transmit again, etc. This could cause a feedback squeal and other symptoms.
May 30, 2009 | Uniden PRO538W (40 Channels) 2-Way Radio
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Trouble transmitting & receiving on uhf.
While there might be a multitude of answers to this question. The first would be the radio is in need of repair, or not programmed correctly.
Jul 07, 2008 | Uniden Radio Communications
Cobra   Two Way Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
