Question about Panasonic Lumix DMC-FX12 Digital Camera
Lens won't open - Panasonic Lumix DMC-FX12 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 10, 2010
Lens stuck
Please see this link for troubleshooting steps for a stuck lens.
And here's a video summary of the steps.
Apr 28, 2013 | Samsung S860 Digital Camera
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Nikon p2 lens erros lens won't open
This link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-camera
Hope helps.
Aug 14, 2012 | Nikon Coolpix P2 Digital Camera
My lens won't open
The gear linkage in the lens is seized or is out of alignment, this is a job for a camera specialist, I recommend estimate first.
Jun 23, 2012 | Canon Sx150is Powershot Sx150 Is 5664b001...
Where is the lens to clean on Sharp component system?
Hello
To clean the lens, you have to open the device and access the loading mechanism. it is really a skilled job. If you want to clean the lens only, there is a simple way. Just put in a lens cleaning disc into the device, and play it for about three times at least. Take the disc ejected each time, and put it in after. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your town, and won't cost more. You can clean the laser head lens, by this way, without opening the device. OK.
Dec 22, 2011 | Teac Audio Players & Recorders
Turns on but the lens won't open
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Jul 30, 2011 | Kodak EasyShare One Digital Camera
When camera is turned on the lens won't open, message comes up lens error will shut down automatically
Was the unit dropped or were any liquids messed onto the lens assembly previously ?
If dropped (particularly if the lens was open) the lens drive mechanism might well have suffered damage.
If liquids, particularly ones containing sugar, were accidently messed onto the lens assembly, then the sugar becomes sticky as the liquid dries, effectively glueing the mechanism in place.
Jun 11, 2011 | Canon Cameras
Panasonic Lumix DMC-FX12 Digital Camera Logo
210 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
