Question about Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player
Cant buy pass brake on my vm9311ts
Cant buy pass brake
    Problem Solver:
  • 13 Answers
Use toggle switch on inout bypass code with remote
Posted on May 12, 2010
Humming noise driving
all brake pads can sing. all.
and is not a problem at all. they vibrate like a guitar string.
when very lightly pressed (you only said pressed, so.....)
some folks hate this,
so buy the no sing glue for the backing plates or add the High MPG
springs that retract the pads. ()mods)
the older cars the caliper piston seals, lose a property called the stiction
factor (this helps retract the piston) so new seals can help.
the seals do act as tiny springs. when fresh. and new.
sticking caliper guide pins took, can cause noise.
some can rust. my jeep has sst pins in teflon sockets that cant rust.
BTW3?
some cars have missing parts, in the pads, due to shoddy brake work.
they dont put back the anti squeel shims and such.
so go to honda dealer oem parts. dot come and see your brakes
and all parts that came new on car. missing parts . ?
Feb 06, 2014 | Honda Cars & Trucks
Honda passport 1994 4wh drive cant pass smog test. i change the catalytic converter, change the egr valve, 02 head sensor and major tune up, spark plugs, wires are all change still cant pass smog. i passed...
Here are a few things to look at:
Have you replaced the air filter? Have a compression test done on the engine, could possibly be a leaking vale. If any vacuum hoses have been removed from the engine they will have to be re-installed. Solid Lifters out of adjustment can cause incomplete combustion. Make sure engine is reaching proper operating temperature (eg. thermostat). Do not use low grade (octane) fuel for test.
Clean oil, tire pressure, brake drag?, every little thing counts.
Oct 12, 2010 | Honda Passport Cars & Trucks
What is bypass code
put the dvd in and by pass the parking brake with a ground so you can see the movie or what ever is playing and the on a remote for it press stop twice and 1264 and a menu will come up and select parking brake over ride off
May 04, 2009 | Audiovox VM9311TS
Difficulties in installin of VM9311TS
just by pass it with the bypass code
What is passcode for my Jensen VM9311TS car stereo?
on main remote push
stop twice, then 1264, joystick south twice, then once, then sys setup twice to save
Apr 13, 2009 | Audiovox VM9311TS
How do i bypass parkingbreak for a jensen 9311ts on mustang 99
take the parking brake wire should be pink or some funky color and hook it up to a +12 power source.
that way there is no need to use the e brake or anything for it to work
But as a word of caution all this is illegal in most states due to people not keeping their eyes on the road. ive read of people getting tickets for having disabled this security feature on their stereos. some insurance companys will not cover you if there's an accident you are involved in and you by-passed the safety feature. so before you do it, be sure to read your local laws and check with your insurance agent before doing it. you will not be happy finding things out the hard way.
Dec 02, 2008 | Audiovox VM9311TS
Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Sep 21, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player Logo
164 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
