Question about Archos 604 WiFi Digital Media Player
About charging. is there any way of charging the archos 604 wifi other than connecting to the computer?i mean is there some thing like a ac wall charger? thanks in advance.
Thanks a lot.r there any specifications(o/p current ant o/p voltage) about the usb/ac wall charger
Posted on Apr 07, 2008
Just get a USB/AC converter. You can use the same computer cable to plug into the wall.
Paul
Posted on Apr 06, 2008
SOURCE:
How do I download pictures to my Archos 604 wifi
Hello.
Welcome to Fixya's Community.
When you are connected to a Windows® network, you can browse the shared folders of other computers in the network, using the Archos File Browser. From the Home Screen, select the Browser icon. Once in the browser, select ‘Network’. Your device will search for other computers in the Windows® network and you can start browsing their shared contents.
  • Using the Archos double browser, you will be able to transfer files from a computer onto your device, or transfer files from your device onto a computer’s write-enabled shared folder.
Additional Help:
Archos 604 Manual Guide.
Archos 604 WiFi Manual Guide.
Thank You For Using Fixya.
Please let me know If you need any Further Help.
Good Luck.
Nov 09, 2009 | Archos 604 WiFi Digital Media Player
My Archos 604 wifi only play a few minutes after charging.. I have used the dvr, usb and wall charger and nothing helps.. is my battery kaput? also since messing with it the touchscreen isn't working......
it must be the battery..While charging is pilot lamp lightning ?
To verify,just plug the USB cable to see if device battery charging circuit is working..Device should work normally..
If it does,either your battery is dead or its charger needs to be changed.
Kazim
Sep 13, 2009 | Archos 604 WiFi Digital Media Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Archos Recovery (code 2)
Send them back to Archos if they are still under warranty. If not, you're out of luck because they'll charge you about US$140 to repair the hard drive + postage.
Sep 10, 2008 | Archos 604 WiFi Digital Media Player
605 wifi won't start
I was having a similar problem where my 160 gb Archos 605 would not hold a charge even after two days of being plugged in through an AC wall adapter. It worked fine for 5 months without a problem, but then all of the sudden it would not hold a charge even if the LED light was blinking green.
One thing that I found that makes it now hold a charge now is by letting is by plugging it in to a computer. I don't know why, but for some reason, now when I charge it through a computer usb as opposed to the wall adapter, it charges and holds a chrage for over 3 hours. So, maybe try to just let the thing charge through a computer.
Aug 10, 2008 | Archos 605 Digital Media Player
Archos 604 wifi usb connection problem...
Okay, I just started reading your problem and started freaking out because it was happening to me and I suddenly thought that I would have to replace it. But luckily, my only problem was that I needed to prop-up my archos while it was plugged in. I would think that somewhere down the line, me and you have both knocked something loose in the connector. Luck to you, cheers.
Feb 25, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 WiFi
as i am planning to buy archos 604 wifi i just wanted to know about the sound quality of the archos 604 wifi?
thanks.
Jan 27, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 wifi
why dont u try to upgrade the firmware?
Archos 604 wifi
Are you sure the battery is charged? If so, try detach and retach the battery. Also try to attach to your computer via the usb cable and the 604 should turn on by itself, if nothing happens you need to send back to Archos for repair.
Jan 11, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 wi-fi
It's sounds faulty, take it back to get repaired.
Oct 04, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 WiFi Digital Media Player Logo
64 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
