Question about HP Hewlett Packard Pavilion Slimline S3100N PC Desktop
Got the green light in back but no power to the system tried the hold power button for 5 sec thing does not work?
    Scholar:
  • 62 Answers
The green light at the back indicates that the computer is getting power and it also indicates that the Power Box which is known as the SMPS that supplies power is working fine .As there is no light on the front panel it can be that the motherboard has gone bad .To check that u need to open up the computer tower and then remove the memory cards(RAM) there can be one or more than one so with the card removed turn the computer on .In normal circumstances the computer should impart long beeping noise which indicates that the motherboard is fine and if there is no beeping noise then it means the the board has gone bad and needas to be replaced or serviced.
all the best
Posted on May 10, 2010
Kindle fire won't turn on - even after full charge
Press power and volume+ button together until reset screen appears!
Jan 17, 2015 | Tablets & eReaders
I have a toshiba laptop satellite L-300 that won't turn on. I tried unplugging AC and remove the battery and hold the power button for 30 sec. and plugged the AC back, i can see the green light at the...
THE BATTERY LIFE TIMED OUT.TRY IT ON NEW BATTERY FOR TURNING ON THE SYSTEM.THE CHARGING ADAPTER MAY BR ALSO A PROBLEM TRY TO CHECK IT AC VOLTAGE LEVELS .
Sep 03, 2011 | Computers & Internet
When I try to start io my netbook, it sounds as if the disk is going, like it does when it starts up normally, but the green processing light doesn light up and it starts to sounds as if the disk is...
1. turn off your netbook completely.
2. unplug the ac adapter and remove the battery
3. press the power button for about 5-10 secs
4. plug in the ac without the battery and turn on the system
-if still doesnt work unplug the power cable and press the power button for 5-10 secs
5. turn the netbook upside down
6. locate the memory door and reseat the memory
-make sure that the memory is properly installed from the slot
then put back the memory door and all the screw
7. restart the computer
Sep 06, 2010 | Acer Aspire One PC Notebook
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
My tom tom won't turn on. While charging it, the green light goes on, but pressing the power button does nothing. It's just dead. Is there a solution?
I had the same problem with the go 920, I thought it was broken,
Solution was to insert pin into reset hole for 15 Sec, after which hold the power on button for at least 5 Secs
Jan 01, 2009 | Tomtom GO 720 GPS Receiver
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
The power cable light on my Toshiba Portege 2010 flashes yellow/orange when the plug is inserted. Computer will not turn on (green light on power button doesn't even come up). Have tried: 1) starting up...
One thing could be that your A/C adapter has failed resulting in your battery not being charged. This would explain why you're experiencing the same symptoms w/ or w/out the A/C adapter.
Apr 04, 2008 | Toshiba Portege 2010 Notebook
HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Logo
255 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
