Fan runs but wont cool - Heating & Cooling
    Problem Solver:
  • 10 Answers
The 2 most common issues are a freon leak or the outside unit fan start capacitor goes out. It's more likely a capacitor issue. They fail regularly. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Posted on Aug 14, 2011
  • 82 Answers
Fan may be running...but you need to see if the compressor that moves the freon is running
Posted on May 10, 2010
  • Joe Joe Aug 14, 2011
    The 2 most common issues are a freon leak or the outside unit fan start capacitor goes out. It's more likely a capacitor issue. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
INSTALLED NEW COOLING FAN 07 FORD EDGE. NEW FAN WONT CUTOFF
Cooling fan module ! Do you know what it is ? Did your fan assembly come with new fan module . why did you replace fans in first place > 2003 Mercury Grand Marquis how to test the cooling fan
Sep 23, 2016 | 2007 Ford Edge
My coolin fan wont come on wat should I do
Cooling fan is controlled by a relay and a temp sensor. You need to check that each piece is working.
Run power to the fan. fan run? fan ok.
Bridge the relay. Fan run? run power to the relay coil. Fan run? relay good.
find temp sensor. replace.
May 29, 2015 | Cars & Trucks
Why my 2006 nissan maxima cooling fan wont come on
Defective fan thermostat, fan motor, or the engine is cool enough that the fan need not run.
Bypass the switch and place 12 voltes directly to fan motor to see if it will run.
Oct 21, 2014 | Air Cool Dryers
Fan wont run on auto
Make sure your tstat is programmed for electric, not gas. Or in the settings you want that the TSTAT CONTROLS THE FAN.
May 23, 2017 | Dometic Rooftop RV Air Conditioner
I have a 901650 intertherm and the fan outside turns on but the air conditioner inside does not work. What could it be?
!st off, do you mean the indoor unit does nothing period as wont run? or wont cool?if it wont run, the checking breakers/fuses etc is a waste of time, as the transformers clearly providing the 24 volts to operate the contactor outside.If you switch your fan to "on" does the fan run?if not, check fan relay, or board or motor/cap etc.If the fan does run with the fan switch set to on, but not in cool mode, the auto function that sends power to green /fan via yellow?cool terminal in the tstat is open and not allowing the 24v to energize the fan relay.
Feb 24, 2012 | Heating & Cooling
4.1 engine. cooling fan wont come on.How can I test the fan motor? Or is itthe sensor?
disconnect the fan and plug it direct to battery using some jumper wires(speaker wires do fine) and if it runs then there is a problem with a coolant sensor or a cooling fan relay. If it doesn't run, then u need a new fan.
Jun 27, 2011 | 1985 Cadillac Fleetwood
How do i check the cooling fan my car is over heating
HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD NEED REPLACING. IF FAN RUN WHEN HOT WIRED. CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD.YOUR ENGINE COOLANT TEMPERATURE SENSOR NOT WORKING.IT CONTROL COOLING FAN AT SET TEMPERATURE IF SENSOR OPEN OR FAULTY THE COOLING FAN WONT TURN ON.CHECK COOLING FAN WIRES FOR DAMAGE.IF ALL STILL CHECK OUT GOOD HAVE VECHICLE SCANNED FOR PCM FAULT.IF IT FAILS NO COOLING FAN WONT TURN ON.
Dec 13, 2010 | Hyundai Elantra Cars & Trucks
How do you check a cooling fan that wont run on 2002 grand cherokee
ELECTRIC Cooling Fans are Controled By
1) Coolant temp Sensor
2) Cooling Fan RELAY
3) Power source TO the RELAY ( Fused )
UNPLUG the Cooling Fan PLUG @ FAN Itself
Use DIRECT CURRENT AT the FAN PLUG<< +POS & --NEG FROM BATTERY ONE BRIGHT COLORED WIRE at FAN PLUG is +POS. the Other is --Neg If the Fan COMES ON then your Problem IS BEFORE the FAN @ ONE of the 3 OTHER COMPONENTS ABOVE
Jul 16, 2010 | 2002 Jeep Grand Cherokee
Radiator fan not working
CHECK FUSE AND RELAY.IF ALL IS GOOD.HOT WIRE COOLING FAN USING JUMPER WIRES.USING CAR BATTERY.IF FAN RUNS.ITS GOOD.IF FAN DONT RUN.REPLACE FAN ELECTRIC MOTOR.ALSO SCAN IT. TO MAKE SURE COOLANT TEMPERATURE SENSOR IS NOT OPEN.MAKE SURE ENGINE COOLANT TEMPERATURE SENSOR AND COOLANT TEMPERATURE READS SAME ON SCANNER IF NOT REPLACE THE COOLANT TEMPERATURE SENSOR. SEE IF COOLANT TEMPERATURE IS BAD THE COOLING FAN OR FANS WONT RUN.
Sep 07, 2009 | 1997 Plymouth Voyager
My dell inspiron 4100 cooling fan wont turn on
I would get a new fan. you can get a new fan and heatsink by clicking here
Really hope this helps you.
Dec 12, 2008 | Dell Inspiron 4100 Cooling Fan -...
Heating & Cooling Logo
149 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
