Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Engine is surging when in idle
Unless I up the idle speed the engine will surge very badly. I do very regular maintenance use gasoline additive for winter storage change plugs every year change fuel filter every year change oil every 20 hours.
  • 623 Answers
Sounds like the low speed idle circuit is clogged or the inlet needle tip is clogged in the carb. About the only way to clean these is disassembly.
Posted on May 10, 2010
Why does engine surge only when a/c is on?
It is supposed to do this. The PCM commands a slightly high RPM when the A/C compressor kicks on and off.
Apr 08, 2016 | Cars & Trucks
Caddy just started surging at road speed with throttle steady. Idles fine, and when you mash the gas performs fine, just surges and jerky at steady throttle about 40 to 55 mph.
Sea Foam will clean your engine - intake, injectors, combustion chamber, etc. "Hi Test" will not.
Higher octane fuel actually has higher resistance to exploding. High compression engines need higher octane to prevent 'pre-combustion' or detonation (explosion). Diesel engines do not have a spark plug and rely on diesel fuel detonating due to the very high compression (sometimes 2.5 times what you see in gasoline engines). When octane is not high enough, just the compression stroke will cause the gasoline to detonate on its own prior to the spark plug firing, causing pinging or knocking.
So, DON'T USE 'HI-TEST' gasoline to clean out your engine - it will NOT perform that function for you!!!
Feb 03, 2015 | 1999 Cadillac DeVille
When I start my odyssey it starts surging. I found a small rubber hose on the right side of the engine, but don't know where the other end of the hose goes....Help
WHAT COUNTY???????????????????????????????????
hot engine, cold or both?/// a key question
WHAT ENGINE: ( usa list , ONLY)
2.2 L F22B I4
2.2 L F22B6 I4
2.3 L F23A I4 2.3 L F23A7 I4
the fsm covers this. hose thing.... all hose can be followed,
unless its axle vents on 4wd cars. (they go no where, special)
is surging the only symtom.?
no engine stalls.?
lack of power in any gear or hills.
no misfiring?
no flooding.?
starts easy/?
ok what is surge, that it really is idle controls bad or out of comtrol
1: idle controls bad. (isc dead?)
2: or engine is running way too lean, and ISC cant keep a grip on idle.
easy huh?
and #3 misfiring so bad the idle controls fail.
are all fuses good?
is the CEL lamp glowing , then goes out running engine.
no , the scan it. or do the flash DTC codes trick.
a good tech ,first finds out if the engine holds closed loop status
hot. at idle, if not, he fixes that first.
as he/she knows that idle is the last thing to work right, in EFI.
one other way to get surge is air leaks (aka. vacuum leaks)
if the engine (unsaid option) is MAP based, it will race fast
with any vacuum leak, and it dont take much of a leak
to make the ISC idle controller go nuts.
so repost , hot/cold both questions
and actual RPM numbers. we need numbers
is the dash Tachometer missing. ????
and what engines in car.
all lean engines surge.
all ISC systems can surge if out of control , not all do this. just 1/2
if the ISC surges, it means its trying hard to gain back control.
this is called a software servo loop.
The ECU is programmed to hold rpm near say 800 RPM hot.
and is very digressive in that role.
I have a 91 car that will surge, with any vacuum leaks.
(by design) depends on which engine.
Feb 15, 2014 | 1995 Honda Odyssey
I have a 99 civic 4 door and the engine surges at idle
hot engine or cold, or both???????????????????
surging or hunting idle is complex but for sure the ECU has lost control of idle speed , there are 2 macro reasons, (vast causes)
1: ISC is stuck (in non SAE terms, the idle speed control valve ) is stuck.
2: engine is missing cause the ISC to GO NUTS trying to control
idle and can not.. the 50 reasons, , have list ask.
we do tests to find out if either or both the above are bad.
do you want tests, or guessing>???
Jan 22, 2014 | 1999 Honda Civic
97 toyota surges at an idle
(which engine. ?????)_
as always check all fuses. and scan the ECU for DTCs. first.
there is no need to fix OBD2 cars like 1980 cars (hard rows to hoe)
it can be 2 problems this......
lets fix the easy one first. idle. (and hope for moving issues to fix for free) it idle car is parked, so is 100% safe tests. (not moving)
so it surges at idle.
questions.?
1: hot or cold or both.?
2: low extreme RPM and high at idle.
400 to 800 RPM? surge.
1000 to 2000. what? numbers tell the tale.
first off, idle is the last thing to work right on any engine.
there are many ways to find what is wrong.
fix idle surge way.
i make sure that the engine holds closed LOOP status.
hot idle, if not , i fix that first.
keep in mind if not in closes loop and lean
all lean engine surge and guess what the ISC will add to the surge
because idle is way too slow, so the ECU open the ISC wider
and wider and its still too slow, so the ECU resets the ISC
this cause a worst hunt (surge)
the ECU adjust spark time and the ISC to get 800 rpm. (spec. look up yours)
so say , i see closed loop failed, OBD2 scan page 1
i look at the O2 sensor an its stuck lean.
if stuck lean and it really is (o2 bad?) then its lean and it will surge
examples.
1: i find 02 sensor bad, (only effects idle and light steady cruise)
2: i find fuel pressure at 15PSI , hopeless low .
3: i find all injectors clogged. and lean.
4: with MAF EFI, ( i find maf reading too low, (dirty) causing lean.
5: if MAP car, i find the MAP stuck hard high vacuum causing lean.
not knowing what engine you have or the idle hot surge range,
i can not go farther.
the driving bog tells me,
1: scan the ecu ,get DTCs; do that first.
2: clean MAF if car has one, ask how..
3: check fuel pressure.
my guess is engine is lean. and starving for fuel all the time.
cept WOT.
MAF cars starve for fuel if there are any vacuum leaks.
MAP cars do opposite, they race fast with 100% full power.
MAF is air density EFI
MAP is speed density EFI.
apples and oranges diffr. so what engine.
Jan 07, 2014 | 1997 Toyota Tacoma
Increase then decrease idle when engine is cold especially
cold engine idle surge. (problem)
RPM range of surge not stated
300-700 or 800 to 1500? (range is critical to diagnosis)
bad fuel
running summer fuel in winter (running old fuel?)
needs a tune up bad, see the list in the operator guide.
idle speed controller,sticking or EGR valve same. (clean them)
location not stated, so cant guess about local air temps.?
no other symptoms, lack of engine power? etc?
was it ok last week, or better, when was the last time it was OK?
1week, 1year?
surge , causes, on a tuned engine might be:
1: too lean. so lean the ISC can not control idle. rpm low, stalling
2: too rich, flooding, stalling, spark plugs foul (look at them)
3: weak compression in 1 or more cylinders.
4: bad spark.
5: air leaks, in the plenum causing , ISC to lose control.
why high RPM?
especially?
well that means it fails hot too.
and there is a simple tests. for hot surge.
is engine fully hot? 180F and holds solid there?
say rpm is about 800
and you turn on head lights, heater fan and (not AC) and defrost.
the RPM must hold or the ISC is failing.
ISC -= idle speed controls. (all EFI has this function)
Oct 28, 2013 | 1996 Honda Prelude
clean out the carburetor jets re-assemble then adjust fuel mixture screw until it runs correctly
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My cobalt's engine is surging from 500 to 800 rpms when I come to a stop What's the problem?
SURGING COULD BE FAULTY FUEL PUMP OR IDLE SPEED CONTROL GOING BAD OR TRASMISSION TORQUE CONVERTER WILL CAUSE ENGINE TO SURGE WHILE ITS UNLOCKING AND LOCKING UP DUE TO A FAULTY FAULTY TORQUE CONVERTER CLUTCH SOLENOID.
Feb 28, 2010 | 2005 Chevrolet Cobalt
Coleman Powermate 3000 surging
Check your air filter to make sure it is clean, especially if the gen. has been run in dirty, dusty conditions. Make sure the gas tank vent is not clogged.
Also, pour some combustion cleaner into the carb. through the air intake to clean the carb. It sounds like it is starving for gas.
Hope this helps.
Rob
Sep 27, 2009 | Coleman Powermate Premium Plus 6250W...
Rough idle / engine surges until power is applied
Sounds like a possible vaccume hose leak?
Feb 07, 2009 | 1997 Chevrolet Astro
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,324 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
