Question about Gigabyte GA-8I945PL-G Motherboard
My Gigabyte 8i945pl-g motherboard has stopped connecting to the SATA drives. I updated to F8 bios and have tried all the bios settings for PATA/SATA connection. The drives operate OK in another computer. Any suggestions
  • Adnan Bhatti
    Adnan Bhatti May 11, 2010
    It may be the cable or faulty power connector.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Hi thanks for your question.
I would suggest to-
1. Set BIOS to default. 2. Check the cable that drive is connected with (use know good cable) 3. Try and use different socket on motherboard (if you have one)
If all of this fails I'm afraid this may mean that your motherboard has developed a fault. Best of luck!
Posted on May 10, 2010
Since changing the battery on the Gigabyte 8KNXP mboard the SATA Hard Drive isn't being seen. How do I setup the BIOS for the SATA hard drive to be used & seen for Windows to start up again?
Are you sure that the drive isn't being detected but not being SELECTED as the boot drive? Most older MBs will default to the PATA primary cable to search for the boot disk. When you fist boot up, enter the BIOS. If, under the STANDARD CMOS FEATURES option, you do not see your SATA drive listed, then check the data and power cable connections to the SATA drive. If it still is not, there, then, in the CMOS, check under the INTEGTATED PERIPHERALS to ensure that the ON-CHIP SATA option is enables (or AUTO). If the drive IS there, but just not booting, then, under the ADVANCED BIOS FEATURES, check and ensure that the SATA drive is listed as the FIRST BOOT DEVICE. If it is not, follow screen direction to change the first boot device to the SATA HDD.
Sep 22, 2015 | Gigabyte Computers & Internet
How to change bios setting on GA-F2A55M-DS2 motherboard to install XP
The BIOS should not prevent you from installing Windows XP.
If your hard disk is a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 24, 2013 | Gigabyte Computers & Internet
Sir , I have an Intel D102GGc2 Motherboard .I have connected two hard drives one Sata one Pata . And want to boot from Sata hard drive first . So my problem is that as soon as I connect both the drive...
One needs to be a master and one needs to be pegged as a slave. You can have seperate OS..Win 7 on ons and XP on the other then at post screen you can select which OS you want.
Nov 26, 2010 | Intel D102GGC2 Motherboard
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
PATA boot problem
Did you set the boot options to boot from the PATA drive? Did you set the port mode to legacy IDE? Did you try to let the BIOS determine the type of drive?
Jul 02, 2009 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
Can't Enter Setup/Can't Access BIOS
Could be that your PATA drive is pooched. Have you tried accessing the bios with the sata drive in, how about with both drives connected, how about with none.
Try a ps2 keyboard as well, as it may work on the legacy bios option.
May 01, 2008 | EliteGroup nForce3-A Motherboard
Flashing bios
pull the bios battery for a few minutes and reinsert it , see if it comes back on.
Nov 08, 2007 | Gigabyte GA-8I945GMF Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Gigabyte GA-8I945PL-G Motherboard Logo
251 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
