Hello, my hp compaq nc6400 is getting heat a lot and after a few minutes on it shuts off, then i chek the heat sink was hot , but the fan is working fine, could be a faulty heat sink ??
  • RUI MOREIRA
    RUI MOREIRA May 10, 2010
    WELL THE FAN IS WORKING FINE AND IN THE PLACE THE FAN BLOWS IS COOL BUT IN THE TOP OF THE PROCESSOR IS HOT
  • RUI MOREIRA
    TANKS FOR THE HELP
    President:
  • 4,070 Answers
Hi! It may not be a heat sink problem, but i believe that its a fan problem. You may think that the fan is working fine but the question is, is it strong enough to drive away the heat. Replace the fan, make sure that its strong enough to drive away the heat and I assure you it will be resolved. Hope this helps and have a good one!
Posted on May 10, 2010
  • dj_relly999
    dj_relly999 May 10, 2010
    Alright, thanks for the clarification. I would suggest that you replace the heat sink. It could be the one that needs replacement. Good luck on this.
How to compaq 6400 bios slow
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
Hope these tips will help.
Feb 06, 2014 | HP Compaq nc6400 Notebook
Fan runs hard computer is slow hp compaq nc6000
- Shut down your computer at least two hour a day.
Jan 05, 2014 | HP Compaq 6735s Notebook
Compaq presario cq62 won't start but the caps lock led blinks continuously and the wifi led remains on continuously, tried new cpu, worked for a while and started same problem again.
those are blink codes, learn to count them.
if you pulled the CPU i bet you that you used the wrong heat sink compound.
The CPU shuts off all by itself if too hot. your job is to get the fan working and the heat sink working and that thermal compound right.
hp.com
as the blink codes we are not HP here, ever
https://support.hp.com/us-en/document/c02222922
Jun 01, 2017 | Compaq Presario CQ62-209WM
Hp compaq nc6400 doing installation is automatic shut down what can i do
Clean the fan of dust. Change thermal paste. Check if laptop is overheating.
Jan 08, 2013 | HP Compaq nc6400 Notebook
Am using an mPAQ model:M66SE laptop. it heats up very much and after few minutes it hugs up.until i restart and wait few some minutes and cools. what will i do. the heat sink on top of the south bridge is...
remove your heat sink then clean the surface of the heat sink with clen cloth apply athin layer of heatsink compund and fix the heat sink tightly if the heatsink is dried or worn out the heatsink gets heated up also check the fan is working
Mar 28, 2011 | Compaq Heatsink CPU Heatsink & Fan
My Compaq Presario CQ50-103NR Notebook PC keeps shutting down. Sometimes right away sometimes after a few minutes. The left side of laptop seems to get hot while the right side stays cool. Can You please...
Hi:
You most likely have a heat problem, as you have realized. To fix the problem, your heatsink/fan assembly needs cleaned, and then reinstalled with new heat sink compound. Some disassembly is required, so this isn't an easy job. If you go to a reputable shop, and tell them what you want them to do, rather than just tell them your laptop is shutting down, you should get it done for a fair price!
Apr 23, 2010 | HP Compaq Presario CQ50-103NR Notebook PC
Compaq Presario 3000 incredibly slow firing up, opening up anything. Loud fan all the time too
This advice relates to the Compaq Presario 3000 Notebook series but may also apply to other notebook computers as well.
The heat sink and fan assembly is probably clogged with dust and airborne particles. The clogged cooling parts can lead to heat problems with the CPU. When the system (CPU) gets to hot, the fan has to kick into high gear to try to cool things down. Once you remove dust and debre from the heat sink fins and fan, you will immediately experience better cooling and less fan usage. Your system may also be set for dynamic switching of CPU speed. If you CPU gets too hot, the system will reduce clock speed and ramp up fan and everything will slow way down. Use a good system monitoring software such as Notebook Hardware Control to monitor your CPU temperature, HDD temp and so forth. When the system starts getting too hot, first look at clogged heat sink fins as possible culprit. If you're good at electronics you may be able to service the unit yourself. Get a copy of the system's Maintenance and Service Manual or have a professional do the job for you as you will have to partially disassemble the computer to clean out the heat sink. Depending on the system, the job can take as little as 15-20 minutes once you become proficient at it.
May 09, 2009 | HP Laptop Keyboard for HP Compaq Presario...
My HP Compaq 2710p will not charge
I PUT A HEAT SINK FROM A CPU AND ATTACHED COOLING FAN TO THE HEAT SINK
AND THAN ATTACH IT TO THE BLACK OBLONG LONG RECTANGLE BOX LIKE OBJECT AND IT WILL STAY VERY COOL AND ALSO SAVE THE BATTARY FROM OVER HEATING AND DAMAGING THE BATTERY.
RODGANDYSR
Mar 07, 2009 | Compaq 2710p Tablet PC
Laptop overheating and shutting down
CPU IS OVERHEATING AND OVERWORKING MIGHT BE A VIRUS OR A HANING PROGRAM
Jan 20, 2009 | HP Pavilion dv8000z Notebook
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
