Question about Kenwood KAC-9152D Car Audio Amplifier
How to connect a amp to a 1994 celica route the power cable to the battery
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Put a fuse on your amp power wire bout 12" from battery, run wire to your back of car make sure you have a good ground wire hooked up and a remote wire from your head unit (blue) to the amp and run the speaker wires and you should be good to go. make sure you get the right gauge of wire for you amp. hope this was helpful
Posted on May 11, 2010
How to reset the check engine light on a 1998 blazer
Remove pos battery cable for 15mins reset the computer put back. On tighten pos cable
Jun 02, 2014 | 1994 Toyota Celica
My 1994 celica will not pass inspection because it wont hold pressure. there is a vapor leak dont have smoke machine
You won't find a leak without a repair shop & evap smoke machine
& system diagram, unless you see a rotted hose & get lucky.
You could go thru the entire system & remove & test all components,
but you would be there for a long time & the car is too old to be
pulling on stuff you don't need to
Jan 29, 2013 | 1994 Toyota Celica
I have a 1990 supreme cutlass and i don't know how to change the serpentine belt. What do I do?
2.8L and 3.1L Air Pump Belt
  1. Disconnect the negative battery cable.
  2. Loosen the air pump.
  3. Remove the worn belt.
To install:
  1. Adjust the belt to specifications and tighten the pump mounting bolts.
  2. Connect the negative battery cable.
2.3L Power Steering Belt
  2. Loosen the adjustment bolts.
  3. Remove the power steering belt from the pulley.
To install:
  1. Route the belt around the pulley.
  2. Adjust the belt to specifications, then tighten the adjustment bolts.
  3. Connect the negative battery cable.
See Figures 6 through 15
Fig. Fig. 6: Unfasten the retaining bolts...
Fig. Fig. 7: ... then remove the serpentine belt guard
Fig. Fig. 8: ...
Fig. Fig. 9: ... then remove the serpentine belt
  1. Remove the belt. Clean the accessory drive belt surfaces.
Fig. Fig. 10: Serpentine drive belt routing-2.2L engine
Fig. Fig. 11: Removal and installation of the serpentine belt-2.3L engine
Fig. Fig. 12: Serpentine belt routing-2.5L engine with and without A/C
Fig. Fig. 13: Use an 18mm box end wrench on the pulley nut to rotate the tensioner on the 3.8L engine
Fig. Fig. 14: in. breaker bar to rotate the tensioner
Fig. Fig. 15: On the 3.4L, use a box end wrench, then rotate the tensioner clockwise and remove the serpentine belt
Remove the belt guard or coolant recovery reservoir as required.
Dec 31, 2010 | 1994 Oldsmobile Cutlass Supreme
How do I install the air conditioner / power steering belt
prev.gif next.gif Drive Belt Removal & Installation To Remove:
  2. Raise and safely support the vehicle.
  3. Remove the drive belt shield at the right wheel well.
  4. Place a wrench on the tensioner and rotate the tensioner clockwise.
  5. Remove the belt from the power steering pulley.
Drive belt removal/installation (2.4L) chry-03-24-1194.gif
To Install:
  1. Route the belt on all pulleys except the power steering pulley.
  2. Rotate the tensioner clockwise until the belt can be installed on the power steering pulley.
  3. Release the tensioner.
  4. Confirm that the belt is routed correctly on all pulleys.
  5. Install the drive belt shield.
  6. Lower the vehicle.
  7. Connect the negative battery cable.
Jul 03, 2010 | 2003 Chrysler PT Cruiser
Ignition light does not come on
You need to check the following. Do a load test for the battery. Check, clean power terminals, connectors. Clean fuse & fuse holder in starter relay and in fuse box. Clean ground connection points to batteries - terminal, engine and chassis/frame. Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Feb 07, 2010 | 1994 Toyota Celica
I replaced the starter and the starter relay and battery in my 1997 3.0 dodge caravan and it still will not start. Some how power is not getting to the starter.
Try routing a jumper cable to the starter terminal where the battery cable goes to & then hook it to your positive bayyery connection. Then try to start it. If nothing happens you have a bad ground connection
Jan 16, 2010 | 1997 Dodge Caravan
Change fuel filter on 1994 celica
1994 Toyota Celica 1.8L EFI DOHC 4cyl
The Fuel Filter is located under hood, center, upper firewall, mounted in fuel line.
Common fuel line routing
View of the common electric fuel pump located under the rear seat
Removal Fuel Pump
  1. Remove the rear seat cushion.
  2. Unscrew the service hole cover.
  1. Disconnect the electrical fuel pump wiring at the pump assembly. Check for any fuel leakage while in there.
  1. Remove the gas cap, this will prevent any fuel gas spilling out of any high pressure lines.
  2. Using SST 09631-22020 or an equivalent line (flare nut) wrench, disconnect the outlet pipe from the pump bracket.
  1. Remove the pump bracket attaching screws.
  2. Disconnect the return hoses from the pump bracket, then pull out the pump/bracket assembly.
  1. Remove the nut and spring washer, then disconnect the wires from the pump bracket.
  1. Remove the sending unit attaching screws, then pull the unit from the bracket. To disassemble:
    1. Remove the lead wire.
    2. Pull the lower side of the fuel pump from the bracket.
    3. Remove the rubber cushion from the pump.
    4. Disconnect the hose from the pump and extract the pump.
    5. Separate the filter from the pump. Use a small screwdriver to remove the attaching clip.
    6. To remove the sender, disconnect the wiring from the bracket and unscrew the sender. Remove the screws, connector support, connector and gasket.
  2. Inspect all of the lines, hoses and fittings for any sign of corrosion, wear or damage to the surfaces. Check the pump outlet hose and the filter for restrictions.
  3. When reassembling, ALWAYS replace the sealing gaskets with new ones. Also replace any rubber parts showing any sign of deterioration.
To install:
  1. To assemble the pump:
    1. Secure and install a new gasket, connector and support with the screws.
    2. Attach the sensor and secure the screws, connect the wiring to the pump bracket.
    3. Install the pump filter using a new clip.
    4. Connect the outlet hose to the pump.
    5. Install the rubber cushion to the fuel pump. Push the lower side of the pump into place to secure on the bracket.
    6. Engage the connector to the fuel pump.
  2. Install the fuel sending unit to the pump bracket.
  3. Install the fuel pump and bracket assembly onto the tank. Use new gaskets. Tighten the pump bracket retaining screws to 31 inch lbs. (3 Nm).
  1. Connect the return hoses to the pump bracket.
  2. Install the service hole cover, then the engage the fuel pump and sending unit connector.
  4. Start the engine and check carefully for any sign of leakage around the tank and lines. Road test the vehicle for proper operation.
  5. Install the rear seat cushion.
I hope helps whit this (remember rated this help) Good luck.
Dec 17, 2009 | 1994 Toyota Celica
Sec lock on readio 1994 toyota celica disconnected
call the dealer with your VIN number, they will call the manufacturer and call you back with the code, alternatively, look in your owners manual in the front and rear page, some times dealers write them in there, also look in the radio pages they may have written there as well. Good luck
Nov 19, 2009 | 1994 Toyota Celica
Nothing happens when i turn the key
Hey the 80s celica's had a TSB problem concerning the starting of the cars, so it is a factory wiring problem, I have a 1988 celica and all I did was bypass the ignition with a high amp switch straight to the starter and to + on the battery, hope this helps.
Aug 15, 2009 | 1988 Toyota Celica Liftback
Kenwood KAC-9152D Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
