Question about Breville JK31 Cordless Electric Kettle
Where can i buy spare parts for a breville JK71 jug kettle
5 Suggested Answers
SOURCE: Spares for Breville Electric Kettle
Okay. I took the base off the kettle (made a special screwdriver). Saw that one of the contacts was loose on its 'swage'. Used a pin punch to re-swage it. Bingo! it worked.
Jeff.
Posted on Sep 15, 2008
SOURCE: kettle filter
I had this problem few years ago then i found them some where I do not know where now. I still keep some and on the box it is writen: Melitta-Werke Bentz&Sohn. D.4950Minden Best. No. 0-1000-07(Pa 102/40) D-EA Made in Germany it costed me 1.29 D.M for 102 pieces Saleh
Posted on Jun 10, 2009
SOURCE: Dualit glacier blue kettle spare lid
Our kettle has just broken so if you'd like our lid? - if so I'll pop it on ebay?!
Posted on Apr 19, 2010
SOURCE: Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Posted on May 09, 2010
Where can I find a replacement filter spout?
About 683,000 results (0.79 seconds) Search Results
    Buy Kettle Spare Parts ' Calcium filters, Lids and More ...
    www.espares.co.uk/browse/at1102/kettles/small-appliances
    Buy spares for your kettle; kettle filters, kettle lids, kettle descalers and more. We carry parts for all home and garden appliances. ... Find Kettle Spares. Black & Decker. Bosch. Braun. Breville. Brita ... Kettle Spout Filter. Genuine spare part for ...
Feb 05, 2016 | Kitchen Appliances - Others
Where can I obtain a replacement filter for my Breville electric kettle?
I suggest you try "ESpares" they are probably one of the most helpful companies I have ever dealt with and if I have any problems finding bits and pieces for kettles, lawn mowers, washing machines etc this is my 1st port of call. If they don't have it in stock they will probably tell you who will have! http://www.espares.co.uk/
Nov 26, 2014 | Breville Kitchen Appliances - Others
Bulb in Ikon kettle no longer lights up
I had this problem recently; I think my kettle have accidentally been turned on empty. The kettle has a safety for that, described as follows in the manual:
"The kettle is fitted with a safety device, which protects against overheating should the appliance be operated with insufficient water. If this occurs the kettle will stop heating. Switch 'Off' at the power
point and allow kettle to cool before refilling. The safety device will automatically reset when the kettle has cooled down."
Then they go on to tell you that there is an additional thermal cut-out, and if that is tripped, you have to send it back to Breville for servicing. However, it might not be that bad-- it wasn't in my case.
The heating connector and control is made by Otter, here's information that I was able to find about it on their website (Otter A1 and CS7 control and connector-- I think the kettle actually uses a CS4 connector, but the thermal cut out isn't described on that data sheet):
"The A1 control integrates to 360° cordless plug with element
dry boil protection. Two bimetals spring loaded against the
element surface make a fast response during dry boil. One
bimetal disconnects the live side of the electric circuit and the
other disconnects the neutral. A latch out function prevents
dry boil cycling. This automatically resets when the kettle or
jug is lifted from the cordless base."
http://www.ottercontrols.co.uk/support-downloads/domestic-data-sheets
So what does this mean to you? If you look at the bottom of the kettle jug, there is a circular indentation that slots into the base. There are two white plastic things which I believe are part of the "latch out" described above in Otter's documentation. If you see them sticking out, they may be stuck in position instead of resetting as they should. Use something like a pencil eraser to gently poke them so they unstick, then put the jug back on the base. That should cause them to retract, and at that point your kettle should work again.
Nov 07, 2013 | Breville SK500XL Stainless Steel Cordless...
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
The on/off switch on my breville jk164 kettle has snapped off. Can it be repaired or a new switch put in?
Ring breville and ask if this part available,if so ask for price of part and repair costs .
Total it up, might be cheaper to buy a new one these days.
But do not repair yourself unless you are a competent electrical trades person.
Electricity is dangerous.
Sep 12, 2010 | Breville Kitchen Appliances - Others
Feb 07, 2009 | Breville Kitchen Appliances - Others
Jeff.
Sep 15, 2008 | Breville Kitchen Appliances - Others
Breville JK31 Cordless Electric Kettle Logo
240 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
