Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Dishes not clean. Glasses have a film on them. even on the long cycles dishes don't come clean. Did add salt and rinse solution which helped a little.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Posted on May 12, 2010
Milky water when rinsing in dishwasher & gritty covering on dishes
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Jan 19, 2016 | Siemens Dishwashers
Cloudy dishes
cloudy dishes, white generally means an overdose of salt in the dishwasher, try turning down the salt setting usually set to 4 from factory
Oct 24, 2012 | Bosch Dishwashers
After running a full cycle the dishes have a film left on them. Sometimes soap is not rinsred off the dishes. Tried different soaps for dish washers. It seems the only thing to take the film off of the...
Film on dishes post cycle is caused by 2 things.... Poor water flow during the wash / rinse cycle.... i.e clogged sump inlets or restricted drains. Clean the drain hose first. Start at the cink connection and clean EVERY connection and in-line componenet from the port hole at the sink connection all the way back to the drain hise connection port at the dishwasher.
If you still have dirty dishes post cycle after drain cleaning... then remove the lower wash arm support and clean the accumulator / sump area thoroughly. See this link: (items 1 and 4) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140844&diagram_id=28222738#d28222738
Test again.
If the problem persists you will have to gain access to the pump impeller. Inspect the impeller, and pump housing for damage. UNDER the dishwasher. Item 22 of the above link.
This should get your diswasher performing properly again.
I used this model number as a reference: GU2400XTPB1
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My dishes are coming out with a kind of film on them -- especially the silverware and glasses. Now the plates even look like they have a film on them. The dishes are often still dirty.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 13, 2011 | Bosch Dishwashers
Frigidaire dishwasher FDB1500LFCO is not cleaning dishes properly. Glasses have a cloudy apprearance, other dishes are not clean, silveware is a mess. Have hard water so am using LemonShine for hard...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
Dishes are coming out streaked and not properly cleaned. I have added rinse aid, salt and even descaler.
De-scaler wont wash your dishes. The simplest cause of dishes coming out unclean is over-loading, bad stacking (spray arms blocked), or using too short a programme for heavily soiled dishes.
If it's just streaky (not food remnants), you may have the rinse-aid set too low. Open the flap where you add rinse-aid and you will see a know with an arrow shaped grip. There are 5 positions for the knob marked 1 to 5. Try a higher setting (1 is low) but don't go too high as this will cause other problems. If it's on 1, try 3 and if it's on 2 or 3, try 4 or 5. You may have to adjust this a couple of times until you get satisfactory results.
Howver, If you're referring to a white powdery residue on dishes and glasses, that's an entirely different answer . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
Smelly dishes
Aug 17, 2009 | Zanussi 18 in. DE4744 Free-standing...
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishes not completely clean or rinsed, and mold
get some dishwasher salts and unscrew the cap at the bottom of the dishwasher empty the filters and run the cycle. fill up the water with dishwasher salts in the white unscrewable cap put about two cup fulls in.there it should work better then. there is also a product called rinse add you can by this from the local supermarket. hope this helps
Mar 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
