Question about Magic Sing Along Consumer Microphone
I have a magic sing and i plug it in the lights go on but the power has a red light.I try presing the power but it still the same.
  • 2 more comments
  • dyada May 10, 2010
    its the base of karaoke that im trying to tun on
    i have a ED-11000 the main station is giving me the problem
    i have a migic sing and the power on the main station has a red light and dont want to turn on its a ED-11000
    how will i do that or wer will i go to get that fix
    President:
  • 2,468 Answers
You have a short circuit or shorted component in the "switching power supply" circuit in the unit and its staying shut off so this problem doesn't ruin more internal components due to higher than normal current draw from this problem,you will need to have the unit diagnosed
Posted on May 10, 2010
  • danny Hendrickson May 10, 2010
    you will need to find an electronics tech in the audio and power supply field that can assist you in this area,check your local yellow pages or electronics retailer as they may have a list of repaieres in this field
    President:
  • 4,070 Answers
Hi! The unit's battery may be faulty thats why it still has red lights even when fully charged. You may need to replace the battery to get it back to normal working. Hope this helps and have a good one!
Magic Sing ET19KV On connecting Magic Sing through RCA Cable, get buzz sound on my speakers Have chked on diff TV's and replaced the RCA cable.The Video is clear, but getting buzz on speaker
Most buzzes are caused by one of two things: "DIRTY" power or a lifted\non-existent ground. Allow me to explain;
"DIRTY" power is just that. It comes in and carries a lot of static with it. Most newer systems have filters built in on the power side of the main board. The fix? Try running your Magic Sing from a wall socket that doesn't have anything else pulling from that particular circuit. You should also invest in a GOOD power strip and not one that cost $5-$10 bucks. All these are good for is getting power to multiple products simultaneously, AND they don't have the resistors and filters to give you a constant 120v AC.
Monster Cable Co. was a very sought after item up to the point to where Radio Shack no longer carried their products.
If you really want to get your money's worth out of the instruments you buy, don't slack on the power strip. This will be the most costly mistake ANYONE can make.
Here is an article that explains what I did and gives you answers on how to fix this issue.
Hope this helps. Dirty Power What It Is and Why You Need to Clean It Up Schneider Electric...
Aug 12, 2017 | EnterTech Magic Sing Et19k Et-19k Et19kv...
Blinking the power on light when you power on
If the light is flashing when you power the shoes on, then there may be activity in the system and it is telling you this.
Mar 19, 2014 | Vans Woessner Shoes
Magic Sing ET-18k output delay
The delay is introduced by your high end HDTV. To alleviate this problem, connect the music part carried by the red and white wires a separate analog sound system.
May 15, 2010 | Magic Singalong Karaoke Consumer...
Change from PAL to NTSC
You need to configure it out.
1. Connect the magic sing in your TV
2. Turn on your TV
3. Magic sing should be Off
4. On your magic sing; Press and Hold "8" then while holding "8" press "power button", count for thre seconds then release both buttons (PAL to NTSC)
or
On your magic sing; Press and Hold "9" then while holding "9" press "power button", count for thre seconds then release both buttons (NTSC to PAL)
Mar 02, 2009 | Magic Sing Along Consumer Microphone
Can't power ON...
See if the microphone connector wiggles. It shouldn't move, but if it does, the legs on the connector can snap inside.
Aug 14, 2008 | Magic Sing Along Consumer Microphone
Magic sing
hi i am working in Wow Magic sing- one of the magic sing distributor in Philippines. Is your unit wow , even if its our competitor, the manufacturer is just the same.
kindly give me more detailed information about the model and description. please be more specific.
please try to remove all song chips- if there are any...inverted and dirty song chip wont make the microphone turn ON.
check the cable and cord- open (loose connection) cord or open adaptor will not make it work as well.
Apr 17, 2008 | Audio Players & Recorders
Magic Sing EG-18000 Microphone Delay
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Mar 16, 2008 | Magic Sing Along Consumer Microphone
Magic sing karaoke
has anyone found a solution for this?????????????????????????????????????????????????????????????????????????????????/
my sisters stopped working... the blue light on the base goes on.. the mic lights don't work and the screen doesn't work
Sep 25, 2007 | Magic Sing Along Consumer Microphone
Magic Sing Along Consumer Microphone Logo
77 people viewed this question
Top Magic Audio Players & Recorders Experts
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Lyle Siemens
Lyle Siemens
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
