Question about Epson Stylus Photo R200 InkJet Printer
Two red lights blinking, power light off
After a sheet of paper folded inside, the lights came on; I shut the printer, removed the paper & checked everything free. Turned back ON but after a few moves of the head , lights came again.
I took everything apart to check if anything could interfere; did not see.
Reading the blogs, i noticed it's a very common occurence.
Could it be some kind of safety that have to be resset ? it cannot be a fuse since nothing stopped the machine to make a high electric load?
  • 2 more comments
  • cazzyb Apr 18, 2008
    just changed my PC from XP to Vista Premium, and have been using my Epson R200 printer, without problem, then added the CD print section yesterday, printed 2 items, switched on today and both red lights are flashing with no green power light on.
    I have unplugged, and plugged in again, no paper jam, cartridges are new, help please?
  • Anonymous Apr 22, 2008
    r 270
  • Anonymous May 02, 2008
    removed paper  and turned set on. same problem two red lights blinking.
    checked to see if any rubbish. none. cannot seem to do anything. what else
    could i do?
  • Norman Cockerill
    Norman Cockerill Feb 04, 2012
    So, how would one fix an Epson R200 after as per that said by Jean-p on Mar 28, 2008 - my R200 has been out of action for six months and no nearer to resolution, other than to Bin the Epson and buy a Cannon or similar - any ideas please that would not put me to yet further expense of postal expense?
You need to reset eeprom using the software
http://www.yoreparo.com/foros/download.php?id=2057
today i fix a epson r200 with that
Posted on Apr 07, 2008
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Epson Printer Problem
HI,
Press the fonts.gif load/ejectbutton. The printer ejects the jammed paper and then resumes printing.If the error is not cleared, open the printer cover and remove thejammed paper. Then reload paper in the sheet feeder and press the fonts.gif load/eject button. The printer resumes printing.
Jul 24, 2008 | Epson Office Equipment & Supplies
Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
Nothing else for it with your, take the drum and toner out and check for bits of paper.
Mar 11, 2017 | Brother HL-5370DWT Laser Printer
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
Red light is blinking. Do not know why. How do I
Unfortunately, only way to see the error codes you have to get the printer to give you a green light so you can print out the configuration page. Far as the red light blinking, there could be a number of things it could be.
First, make sure the toner cart is installed correctly
- Check to make sure that there is paper in either the pull out for fold down tray.
- Check to make sure that there isn't a paper jam. Remove the toner cartridge and check to see if there is any paper stuck inside.
If you get the green light after checking those things, press both buttons down for about 2 seconds and release. On the configuration page there will be a set of numbers that indicate what the error codes are. If you can get me that information I can tell what they mean.
Aug 03, 2009 | HP LaserJet 2100 Printer
My laserjet 2550 won't print. The light beside the triangle is blinking but I don't know what that means.
Hello there,
What is the color of the blinking light? Is it red or green? If its red, then there must be a cartridge issue or paper jam. Did you load the paper correctly? Also, please try to do a reset of the printer.
Aug 03, 2009 | HP LaserJet 2550N Photo Printer
CANON I960 BLINKING RED LIGHT 2TIMES
is the piece of paper removed? or there parts of the paper w/c was nt removed? if the whole paper was removed already, try to use this steps..step 1. remove the power cord of the printer. step 2. press the power on/off of the printer while plugging the power cord. and wait for 10 seconds before releasing the on/off button..then put on your printer. but if some pieces of broken paper inside the printer try to clear it first then try printing.
Jan 02, 2009 | Canon I960 InkJet Photo Printer
Cannot print
If this is a 2200dtn, have you checked the duplex turn around tray under the printer? You can access this by removing tray 2, inside on the front left you should see a small green tab which will release a drop down tray. Many times a sheet or even just a piece of paper can get lodged in the sensor causing a paper jam condition.
Nov 21, 2008 | HP LaserJet 2200dtn Printer
Paper jammed
I had exactly the same problem, printer virtually new, printed great for a couple of weeks, then today refused to take paper with E3 flashing. No apparent blockage - all looked clean, tried all the utilities, roller cleaning and plate cleaning, but wouldn't take paper!
Solved it by moving the paper size guide all the way to the left, then folding the top 20mm of a sheet of A4 over and loading it so fold is at the top facing you. This acts as a catcher for anything stuck in the printer. Hold the paper slightly crooked with the left side slightly further into the printer and press the copy button (with nothing in the scanner!). It should draw the paper in now (with some persuasion) and think it is printing (it's blank,of course). Check as the top of the sheet goes in that the fold is still tight and doesn't open up as it feeds in. Lo and behold, mine brought out a 5p piece - printer now prints perfectly!
Mar 20, 2008 | HP LaserJet 2100 Printer
Epson Stylus Photo R200 InkJet Printer Logo
146 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
