Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Color problems my projector picture has a green hue sometimes flickering sometimes solid. just got the bulb replaced today and still have the problem
  • 1busaboy Apr 29, 2008
    I use this unit as a TV. When it first turned on the color is great but after about 10 minutes the color begins to fade and the screen will sometimes flicker. The picture appears reddish almost. The warning icon for lamp life kept coming on so I replaced the lamp and of course this did not alleviate the color issues.
  • Anonymous Jun 23, 2008
    The color flickers and then turns everything green.
Check out this thread: http://www.fixya.com/support/t138974-optoma_projector because there they say it's due to dust.
I'm having the same problems with my ep770, and am going to give it a try.
Posted on Apr 29, 2008
  • 563 Answers
Hi there
Have you tried using a differnt cable ?
If you have and this doesn't help - then your Mainbaord may the fault.
Posted on Apr 02, 2008
My projector has a blue flickering hint in the picture, is it a lamp related issue, or is it a lcd problem.....?My lamp do needs replacing because the indicator says so.......but will replacing the lamp...
blue flickering hint, means the lcd panel is break,
or polarizer is break. We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jul 12, 2013 | Epson Replacement Lamp ELPLP30 f EMP-61...
Just replaced my optoma hd65 lamp with an original optoma lamp and the picture color is great but there is flashing/flickering of the colors on the screen periodically, sometimes more often. I reset the...
Try putting the bulb into normal (rather than eco) setting.
Check the bulb is seated correctly.
If this does not help you may have to contact your bulb supplier to see if they can swap bulb for you.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Optoma HD65 DLP Projector
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
I have a Infocus Screen Play 5000 bulb has 324 hours the picture is light green.
try reflashing the firmware, check your cables by wiggling the ends coming out of the projector and watch the picture for any changes, if it goes to normal at any time, your cables are just worn out. if that doesn't do the trick, maybe your lcd polarizers are burnt, i really need a better description of the picture.
Apr 01, 2010 | InFocus ScreenPlay 5000 Multimedia...
How to fix yellow hue center bottom of picture.what causes this
Most often color distortion is due to the bulb wearing out. Projector bulbs often fade or distort colors before they actually burn out. The other thing you can try is to reset the projector to it's factory settings, which sometimes fixes color issues. It's usually an option in the "settings" area of the menu.
Jan 18, 2010 | Sony VPL PX40 Multimedia Projector
Lots of details: LP120 stays on for a minute, then powers off
either the colorwheel motor is not getting up to speed to sync with the dmd chip, the wheel sensor is going, or the power supply needs replacing. you can try to replace them yourself or send it to an infocus authorized service center. try www.avsolutionsny.com . they're pretty good.
Sep 29, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
Image flickers and colors off
I have the same problem as philvo. I was watching, the projector was operating normally, I heard a snap, there was a flash of light behind me I believe, and my Mitsubishi XD300U projector went to a black and white picture. That is all it will show now. All lights show normal operation. I would like to know if it is worth getting repaired. Does anyone have any ideas?
Jan 07, 2008 | Mitsubishi XD300U Multimedia Projector
484 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
