Question about Miele Dryers
Novotrinic T294C: The dryer is working but there is no heat and the clothes remain wet.
  • Miele Master
  • 19,396 Answers
Hi.
Trip circuit breaker for two minutes and check the state of the lint filter.
If that does not help, the first step is testing and eventually replacing the thermal fuse.
The thermal fuse is located in the blower housing, at the back of the dryer. The thermal fuse cost is only few dollars. Before replacement it can be tested reading Ohms with a multimeter. If the multimeter set on impedance reads infinite Ohms (No continuity, same as on air), then the fuse must be replaced. A good fuse must read low or zero impedance.
If the thermal fuse is OK, the next parts to test are the thermostats. On Miele dryers there are at least two thermostats. One is a control of temperature, the other is an high limit.
The thermostats are tested reading Ohms at room temperature. If any of them returns no continuity at room, then the thermostat is faulty and must be replaced.
If the thermostats and fuse are OK, then the next step is checking the element and fan. The element is tested reading Ohms on solenoid with multimeter set at Rx1. If the tester reads no continuity, then the element is faulty. The fan can be tested jumping its contacts to energize it directly.
If all the parts listed above are OK, then wiring and electronic timer control board must be tested reading voltages at contacts.
The problem is likely the thermal fuse or one of the thermostats.
Apart replacing the part, ensure that the hoses are not blocked , and that there is no lint inside the machine. This may be the reason for the fuse blowing.
Here a general diagram that can help you in identifying parts.
All tests must be done by a trained technician.
To get a technician on site , or to get a quote on repair ring the number listed on the owners manual.
If you live in the US ou can also get a technician contact using Fixya directory:Contacts.
To get parts ring Miele at the number on manual.
You can also use one of the websites listed here to get parts and diagrams:
Where do I find parts and diagrams for my Appliance?
Posted on May 10, 2010
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
My Miele T294C NOVOTRONIC TUMBLE DRYER KEEPS STOPPING AFTER A FEW MINUTES OF DRYING. I CAN SWITCH IT BACK ON IMMEDIATLY ONLY FOR IT TO STOP AGAIN. CAN YOU HELP?
Hi - it seems likely the moisture sensor unit is faulty, reason?
Well Miele dryers after you start up will actually try to work out the amount of moisture in the dryer, it will calcualte the time & temp required to correctly dry the load in the machine. I suspect the sensor is not functioning proper.
I will assume there are no messages or other indications or flashing lights on the right side of the knob - it would be nice to plug my laptop to it and find out for sure..
You have cleaned the heat exchanger unit in the bottom corner of the dryer, the filter in the door and the two on the bottom of the door opening..
Despite all of these I would lean on the faulty sensor as the most likely culprit.
You may have to locate the nearest Miele service agent to help you out...
cheers
Jun 22, 2011 | Miele Dryers
I came home and my dryer had still been running for the whole time I was gone, about 4 hrs. The clothes inside were cold and not dry. This morning I tried getting it to work, but the clothes remained...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 23, 2011 | Roper Dryers
Type:DWSR-NAT-1206006-CV22. The Kenmore gas dryer runs and spins but does not heat up -the clothes remain wet. Lint is not the issue . Iclean the lint trap every load. I also vacuumed out the coil vent ...
heatman101
Apr 03, 2011 | Dryers
No heat
the first thing to check is that you have 220VAC at the plug. If one leg of the circuit drops out you can have this symptom.
Apr 20, 2010 | Bosch Axxis WTA4400 Dryers
Won't heat. and i cant locate the fuse
my dryer doesn't heat up to dry the clothes. The drum is running but there is no heat - the clothes remain wet. Any ideas?
Apr 17, 2010 | Whirlpool LER4634J Electric Dryer
Making a lot of noise, heats up but the clothes stay wet
DRYER HEATS UP AN CLOTHE FEELS HUMID,,,,,,YOU GOT BAD COILS......HEAT IS NOT CONSTANT..POWER TO THE COILS DROP AN THEN COMES BACK UR MAGNETIC COILS ARE BAD
YOU NEED NEW DRYER COILS
May 28, 2009 | Maytag Dryers
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
83 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
