Question about Krups Small Appliances Espresso Machine
I have a problem with my Krups XP7240, it is
I have a problem with my Krups XP7240. It is stoped and gave error code 06. Do you have any idea?
  • Krups Master
  • 1,711 Answers
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
Posted on May 10, 2010
Krups XP7240 error OC
OC can mean faulty communication between the 2 boards, disconnect from mains & try again which you have probably already done. There is only 1 cable from the display pcb to the control pcb and that is to the top front of the side pcb.
OC can also mean the distributor is drawing too much power, if that's the issue just replace the distributor.
Apr 05, 2014 | Krups XP4030 Espresso Machine
I had some water problems with mij krups and try to solve it. Now it gives an error 0D. What does this mean?
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Feb 11, 2011 | Krups XP7245
Water leaking from the bottom of the XP7225. I empty the cup holder after every two or three uses - no luck. Any idea?
it is a common issue. See the posts for xp7240. The seal within the plunger is worn or dirty or the valve is sticky. Posted both instructions on other posts.
Aug 13, 2010 | Krups XP7225 Espresso Machine
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Jun 06, 2009 | Krups XP4030 Espresso Machine
Error code 06
The error 06 happens because one of the services – Rinsing, Cleaning, Descaling or Replace Water Filter is out of date.
Start in a sequence and go through ALL services. Go to “Machine Information” in “Programme” Mode to ensure that “Last” reads zero or a maximum of something below 10 and your machine will NO longer give start up problem. Please report it if this still occurs, because a computer reset can be done.
Mar 13, 2009 | Krups Small Appliances Espresso Machine
Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
Machine Fault Error No 06 at start up Model is Krups XP7240 Expresso - not listed in product list
The error 06 (comes after start up) and machine in auto test - happens because more than one problem. One of the compulory services, rinsing, change water filter, cleaning OR / AND descaling is out of date. Start off with one at a time and do ALL.
Reconfirm it by going into "Product Information" and confirm that the cycles since previous cleaning, descaling and water filter replacement is ZERO.
Your machine will NOT have start up problems any longer
Regards
Jul 10, 2008 | Krups XP4030 Espresso Machine
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
May 19, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Small Appliances Espresso Machine Logo
2,023 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
