Question about Philips 55PP9352 55" Projection Television
55 hdtv philips having issues with blue and red lines around everything ......
OK I HEARD THAT COULD BE THE ISSUE . IM NOT A TV PERSON BUT IC'S CAN YOU TELL ME MORE GOOD PLACE TO BUY AND WHAT DO THEY LOOK LIKE ... PRETTY BAD HUH LOL ? AND COST FOR SOMEONE TO DO SHOULD BE AROUND ? I REALLY APPRECIATE THE RESPONSE... ARE THEY DIFFILCULT TO CHANGE ? IM PRETTY HANDY JUST NO REAL KNOWLEDGE ON THIS . THANKS AGAIN
  • Philips Master
  • 8,617 Answers
Www.electronix.com should have them for about 10.00 each they involve soldering and dissasembly of the convergence board. A repair shop will charge between 300 and 400 to do the repair depending on where its done.If you go to the link enter STK392-110 in the search box and that will show you what they look like yours are either 392-110 or 392-120s they both interchange with each other, however STK392-120 are a better chip.
Posted on Mar 28, 2008
My big screen magnavox tv shows double lines red and blue
Model number listed here unlikely to have this issue which sounds like a convergence problem.
Oct 21, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Im having colour problems with my phillips 43in hdtv blue and red lines across the screen tried to aligne but didnt help any ideas wat i can do
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Philips 55PP9363 55" Rear Projection...
55 philips replaced ic's as suggested and still red /blue around everything...
Now the heading list your model as 55PW9363 Which model number is your set? If the resistors arent open it has to be a pico fuse, But I wasnt aware that the DPTV series have pico fuses, they do have fusible links solderd directly to the circuits. Let me know your accurate model number. I was under the impression it was the 55PP9352/17 which is the DPTV305 series chassis or Mag01 which is the same except for magnavox
Apr 04, 2008 | Philips 55PW9363 55" Rear Projection...
There will be several that look simallar but look for the STK 392-120 or 392-110. List the stk numbers that you have and I will let you know which ones are the right ones
Mar 28, 2008 | Philips 55PP9352 55" Projection Television
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Philips 50P8341 50 in. Rear Projection Television
Sounds like the blue convergence IC s bad. They are relatively easy to replace if you can solder they cost around 10.00 each and you should change both the red and the blue.
Feb 09, 2008 | Philips 50P8341 50" Rear Projection...
Red and blue
convergence amp ic going bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Philips 55PP9352 55" Projection Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
