Question about GE 30 in. JP340 Electric Cooktop
Loud Pop, blown Breaker
My wife reports she turned on a burner a few days ago and heard a loud pop and saw a bright flash around the pot. The cooktop breaker blew. I turned everything off, reset the breaker, and all seems fine now. Seems fishy to me (SHORT) but I don't see how to open the cooktop. Any thoughts?
  • 1 more comment
  • indorich1943 Sep 28, 2008
    My wife had the same problem. We turned the cooktop off, reset the breaker then in about 1minute it blew the breaker again. The breaker will not reset.
    In our home, the cooktop is on an individual breaker.
  • Anonymous Mar 17, 2014
    The cooktop flashed for about 5 minutes as I was cooking three pots on high, then quit. No lights on the display at all. I have flipped the breaker numerous times.
  • Anonymous Mar 23, 2014
    6 year old Kenmore induction cooktop. Suddenly began making loud vibration noise from any burner and varying pots and pans and gets louder at higher settings.
    Scholar:
  • 105 Answers
Pull the unit away from the wall and inspect from rear. However, if all is fine, perhaps you simply overloaded the circuit that once. Were you running any other appliances (overhead microwave) at the same time?
Posted on Mar 28, 2008
SOURCE:
My amana model AKT3040 is making a loud "pow" when i turn it on with a white flash under the glass, then the breaker trips. It is 6 years old this month, not under warrenty, Should i try to get a repair...
Amana will confirm this - but I am fairly sure that the elements under the glass are replaceable. Most units by other manufacturers are repairable...but if yours is not, then careful shopping around will save a ton on parts cost.
Labor will vary by market...but it is typically better to have the replacement part when contacting a repair service.
Oh, yes, the snap is a broken burner element. the breaker trips because the resistance on a shorted element is insufficient - and the current draw becomes excessiver - popping the breaker.
Nov 06, 2009 | Amana AKT3040 Electric Cooktop
I was roasting a chicken in my Maytag Cooktop when I heard a loud buzzing and a "pop", all of the power in my house went out. Something had tripped the breaker. My husband reset the breaker but my stove...
there is a short for sure, sometimes when the heating element burns out and melts, it touches the metal inside the housing causing a short. inspect the heating elements in the oven(top and bottom). the loud buzzing sound is what a shorting out heating element makes as it melts like a weldin rod, usually because of using tin foil(not recommended)
Jun 15, 2009 | Maytag MEC5430BDS Electric Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Burners on JP326 electric not heating
Sounds like breaker tripped so no 220 to unit. Reset breaker. The burner switch you first turned on probably blew out and needs replacing, so don't turn it on again. If all else works ok, then that is it. Unless you are handy you may want to call the repair man.
Nov 30, 2008 | GE 30 in. JP326 Electric Cooktop
GE Profile JP350 cooktop stopped working
OK, i think the problem took care of itself. definitely got water down in the infinite switch for the lower right burner. let it dry 12 hours and reset the breaker, now works fine. but, i know if i do that again, or if it happens randomly, i will have to replace the switch and seals (available at repairclinic.com)
to do that, you have to remove the cooktop (screwed down by a strap in the back to the back wall of the cabinet) remove the sheetmetal to access the switches and replace. just keep the wiring straight, and ALWAYS replace the seals, they leak over time.
Nov 09, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Cook top "popping" noise
make sure the heater elements are properly nested into their respective electrical sockets. if they get loose, then the electrical contact can be intermittent and arc/spark a bit..
Sep 10, 2008 | Kenmore 30 in. 44022 / 44029 Electric...
Ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Oct 26, 2007 | GE Profile JGP636 Gas Cooktop
GE 30 in. JP340 Electric Cooktop Logo
843 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
