Question about Refrigerators
Vibrating noise from freezer/fridge?
I have had a GE fridge for 2 years. Refrigerator on bottom and freezer on top. Last week a noise started, sounds like regular "running" noise but louder. And 2 times it is incredibly loud. Does not stop when doors are opened. Louder when freezer door is opened. When touch back wall of freezer sound "changes". Please help its driving me nuts!
  • Anonymous Mar 29, 2014
    Noticed this morning the fridge is making a terrible high pitch whistle sound, much louder when we open door to fridge, what is this
    President:
  • 1,314 Answers
Take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
Posted on Mar 28, 2008
SOURCE:
My brand new Beko frost free fridge freezer makes a loud gurgling noise and sounds like water trickling inside every time the fridge door is opened then closed again, regardless of how long its open for....
mINE IS DOING EXACTLY THE SAME - I'VE HAD IT ABOUT 2 WEEKS BUT ONLY STARTED MAKING THIS SOUND TODAY AND AS YOU SAY ONLY WHEN THE FRIDGE DOOR IS OPENED AND THEN SHUT!
Oct 08, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Freezer on bottom is cold,refrigerator on top is warm. 2 days before failure there was a vibration noise intermittently between fridge and freezer that stoppped if freezer door was shut hard
This is a little strange to hear but something caused the vibration. Closing the doors hard or soft may make big changes in sound because of pressure change. I just want to know if the compressor is purring away without overheating. Anytime there is a restriction in ventilation the evaporator fan will struggle to push the air to the freezer and enough to refrigerator side to maintain safe temperatures. On the bottom even if the fan stopped the bottom would work because it is below and cold is heavier than warm. I will look over your parts breakdown to see what vent, dampers or fans that may cause this, work with me on this and I will help you solve this. Thanks Sea Breeze
Jan 21, 2010 | GE Profile PDS20SFS Bottom Freezer...
WATER LEAKING IN MY FRIDGE
OK I will try to help but I see the date of your post is close to 2 weeks ago. Sea Breeze
Jul 07, 2009 | GE GTS22KBP Top Freezer Refrigerator
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Refrigerator Leveling Problem
Buy an inexpensive spirit level ( regular level sold everywhere) and check the level for yourself.. If you push/pull on the fridge..does it rock at all.. if so.. it may be level but the adjustable feet aren't making contact sufficiently to keep it from moving.. If after you've verified it is level.. you can do a few diagnostics on your own.. you can try removing everything on the door inside.. then listen for that noise.. if still there.. remove shelves and food etc.. see if it is still there.. check the snap on grill at the bottom to make sure it is secure.. check the hinges on the doors and make sure everything is snug.. make sure ther isn't anything on top of the fridge that might be vibrating when the fridge cycles.. You have many options here.. Hope this helps..
Aug 30, 2008 | GE Hotpoint 21.8 Cu. Ft. Top-Freezer...
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
Nov 26, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
704 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
