Question about Agfa DuoScan F40 Flatbed Scanner
Initialization problem - Agfa DuoScan F40 Flatbed Scanner
    Problem Solver:
  • 10 Answers
Try to look at your scanner in the device manager if it was present and if it is not present uninstall it and reinstall its driver.
Posted on May 10, 2010
SOUND GOES IN AND OUT.CAN'T TURN IT DOWN WHEN ON
Try a "REBOOT"
Reset, Initialization &
Option Menu
Front Panel Reset & Initialization
Many customer generated symptoms, intermittent symptoms
or symptoms that cannot be duplicated can be resolved
by performing resets or initialization from the front
panel. To avoid making nuisance service calls that may
not be covered under the warranty, ask the customer to
perform the following functions before going to their
home.
The most common are:
• System Reset (Re-boot)
• A/V Reset (Resets Customer Audio/Video
Settings)
• Initialization (Resets all customer options,
settings and menu items)
Use the Front Panel Guide as a reference to quickly
perform the desired function. Note: Button location may
differ by model.
The Reset - Initialization Guide details all resets and initialization
functions.
Front Panel Guide
FRONT PANEL
1) SYSTEM RESET1 - Reboots Set
(Same as Cycling AC Power)
Power LED will flash for about
1 minute.
2) A/V RESET2 <FORMAT+GUIDE>
Resets all Customer Audio/Video Settings
FORMAT GUIDE INPUT
ENTER CANCEL
SYSTEM
RESET
MENU
VOLUME
ADJUST
CH
ADJUST
3) INITIAL2 <FORMAT+INPUT>
Resets all Customer Menu and
A/V Settings
LED DIAGNOSTICS3 <INPUT+MENU>
In case of failure, a 2 digit error code will
be indicated by the POWER/TIMER LED.
1 Perform while the set is either On or Off. (See section on LED Diagnostics)
2 Perform while the set is On.
3 Perform while the set is Off.
Apr 20, 2014 | Mitsubishi WD-73732 73" Television
How to clear back to factory setting
Service-mode functions
NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Super NVRAM initialization
The super NVRAM initialization clears all settings affected by a regular NVRAM initialization, and also
clears the product language and country/region settings. Both settings must be reset after a super
NVRAM initialization.
When the process finishes, the product control panel shows the Ready message.
Apr 18, 2013 | HP LaserJet M1522nf Multifunction Printer...
Boss br900cd factory defaults re install
Here is the newest updates for it, http://www.bossus.com/gear/productdetails.php?ProductId=718
1. Press [UTILITY].
2. Press CURSOR [ ] [ ] to move the cursor to "INI,"
and press [ENTER].
3. Press PARAMETER CURSOR [ ] [ ] to move the
cursor to "ALL," and press [ENTER].
The confirmation message "Are you sure?" appears in
the display.
4. To continue the initialization, press [ENTER] (YES).
To cancel, press [EXIT] (NO) (or [UTILITY]).
When [ENTER] is pressed, initialization begins.
After the initialization has been completed, you are
returned to the Play screen.
You can perform the same initialization with "INIT
ALL," by holding down INPUT SELECT [GUITAR/
BASS/MIC2], [MIC], and [LINE] while turning the
POWER switch ON, then pressing [ENTER].
Mar 03, 2013 | Roland Boss BR900CD Digital Recording...
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
Feb 02, 2013 | Wurlitzer Jukebox CD Player
How can I perform an NVRAM initialization with my HP CM1015 MFP
CAUTION NVRAM initialization will erase all network settings. Before performing NVRAM
initialization, print a Network Configuration page, which contains network-setting information.
NVRAM initialization performs the following actions:
? Resets all customer-accessible menu settings via control panel and software back to the factory
default settings
? Resets the language to the value set at the factory
? Resets the default media size to cold reset media size
? Resets the symbol set to PC-8
NOTE The following steps reset the same NVRAM locations that are reset using the
Restore Defaults option in the control panel Service menu. The following process should be
used if the MFP does not come to a Ready state and an NVRAM initialization is desired.
Use the following procedure to perform an NVRAM initialization.
1. Turn off the printer.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
When the NVRAM init is complete, the printer returns to the Ready state.
Aug 02, 2011 | HP LaserJet CM1015 MFP All-In-One Printer
Initialization failed
You need to uninstall and Reinstall the particular game.. or try system restore for quick resolution
Feb 03, 2009 | Microsoft Windows 98 for PC
Blackberry pearl- initialization problem
I had the same problem and find the answer on other forum http://forums.crackberry.com/f85/huge-problem-about-initialization-failed-sos-113323/ I used some scotch tape and worked perfect for me, the idea is to make the sim card a litle "fat" to fit the contacts.
Good luck
Jan 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Studioplus initialization failed message
This might help to fix the problem
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=221975&Hilite=initialization+failed
Jun 01, 2008 | Pinnacle Studio Plus Version 11
GRRS Setting Using Reliance Smart
cant connect to internet
extra initialization command needed
MTKBTDEVICE (chinees mobile)
vignesh.a@kotak.com
plz help
Apr 20, 2008 | Computers & Internet
Agfa DuoScan F40 Flatbed Scanner Logo
97 people viewed this question
Top Agfa Office Equipment & Supplies Experts
Chris Larocque
Pierre Legault
Are you an Agfa Office Equipment and Supply Expert? Answer questions, earn points and help others
