Question about Peg Perego Vespa Scooter
Vespa gt 125 - I bought it yesterday, road tested it and loved it. Got it home and it won`t start? Any ideas please? It is not turning over but making a slight noise as if it wants to. I`m going to charge the battery but dont think its that as the lights still come on. Please help
  • Peg Perego Master
  • 706 Answers
Might be the wrong key - try the brown colored master key (not black or blue) teste-o4bn0faalxcoa4vjv5kzyzff-3-0.jpg" alt="vespa gt 125 - I bought it yesterday, road tested - vespa-gt-125-bought-yesterday-road-teste-o4bn0faalxcoa4vjv5kzyzff-3-0.jpg" />
Posted on Nov 29, 2014
4 Suggested Answers
  • 7 Answers
SOURCE: I have a Vespa Won't start.
have you tryed kick starting it?
Posted on Jul 26, 2009
  • 7 Answers
SOURCE: Vespa T5 Mark 1 (1989) not idling
cleaned carb and the jet was blocked
Posted on Aug 04, 2009
SOURCE: I have a new 125
change standard seat for a slimmer seat or remove some internal padding iuse a thinner corsa seat from v.e. uk allso wear proper boots with a thicker tread and slide to the front of the seat when stopping it helps as i am small your balancing skills will allso improve
Posted on Nov 20, 2010
What spark plug and cap do I need for Vespa Piaggio 125 automatic
Hi, Tanya for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Piaggio, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
NGK Spark Plug fits PIAGGIO VESPA Fly 125 4 Stroke 125cc 05 CR7EB 4663 eBay
Piaggio Fly 150 4T Workshop Manual
Piaggio FLY 125 2005 Parts
Sep 05, 2017 | Piaggio Motorcycles
2007 Vespa LX 125 wiring diagram
Hi, Michael for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Vespa, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 Vespa LX 125 wiring diagram Google Search
Wiring digram for 2007 Piaggio Vespa LX 125
VESPA LXV 125 Service Station Manual
Vespa VESPA LX 125 2005 Parts
VESPA LX 125 150 Euro 3 User Manual
Jun 07, 2017 | 2007 Vespa LX 125
How do I get the fuse out of my 2007 Vespa LX 150 doesn't slide up when I pull
Hi, William try twisting the housing for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Vespa, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa LX150 jump start problem NEED HELP
http://modernvespa.com/forum/wiki--won-t-start-diagnosis-for-beginners
http://www.vespaclub.org.pl/images/manualki/lx/LX-S-125-150-3v-ie.pdf
Products at Vespa Genuine Parts https://www.vespaforum.com/attachment/16-lx150-handbuch-pdf
Mar 06, 2017 | 2007 Vespa LX 150
Where can I get fitting instructions for Fly125 2010 rear brake cable?
Hi, Brian for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Piaggio, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Modern Vespa Rear brake cable snapped while out riding yesterday
Products GPS Imports
Vespa Rear Drum Brake Adjustment How to
http://www.manualslib.com/manual/455509/Piaggio-Fly-150-4t.html#product-Fly 125
May 16, 2016 | Motorcycles
Vespa engine won't start
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Scooter won start
Vespa 300 GTS Starting Problem
When the Vespa Won Start Scooter in the Sticks
Scooter Troubleshooting Scooter won start All about Scooters
Jan 14, 2014 | Vespa Motorcycles
Vespa px200 won't start
1) did you pull the choke (under fuel tap) ?
2) did you fill gasoline (+ 2% oil mix)?
3) if that does not help get a new spark plug
4) push-start the Vespa in 2nd gear with clutch pulled and let the clutch go after you reach a certain speed (easier downhill)
vespa-px200-won-39-t-start-btrmhpso54mmu3efswgwknhc-5-0.jpg vespa-px200-won-39-t-start-btrmhpso54mmu3efswgwknhc-5-2.jpg vespa-px200-won-39-t-start-btrmhpso54mmu3efswgwknhc-5-5.jpg
Apr 19, 2013 | 2005 Vespa PX 125
Vespa P150X Piaggio won't start
i think it is the CDI-box (at the top end of engine) not working.
check the connectors (pull the rubber cover)
- or better get a new onevespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-0.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-2.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-5.jpg
Jan 03, 2013 | Peg Perego Vespa Scooter
Gears clunk when change on vespa px 125
don't worry -the clunk noise is typical when changing gears on a Vespa 125 PX
- it is due to a very old fashioned construction in the gearbox (1940ies) see pictures:
you have to get used to that or change to a newer automatic type Vespa....
May 22, 2012 | 2005 Vespa PX 125
2007 Vespa GT 200 starter engages when brake lever is pulled
Hi, Anonymous your right-hand control housing starter button has shorted out with the front brake light switch what you need is a wiring diagram that is in the back of your service manual if you can't find the first and best tool you ever bought for your Vespa, despair not, for a mere zero $0 you can download another one.
Modern Vespa Starting Vespa with brake lever
pressing brake to start the scoot issue
2007 vespa gt 200 wiring diagram Google Search
Vespa GT 200 Workshop Manual
VespaGT200
VESPA RALLY 200 Manual
Nov 23, 2017 | 2007 Vespa GT 200
My vespa lx 125 ie is having problems starting, what could this be?
Hi, Josmerriman9 and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Modern Vespa Vespa LX 125 startup problems
Jun 16, 2011 | 2011 Vespa LX 125 ie
Peg Perego Vespa Scooter Logo
211 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
