Question about Acer X193W LCD Monitor
My monitor starts up with "imput not supported" then comes on only when computer is loading up, how do i fix?
  • jimandmonika May 12, 2010
    Thank you profpat for your assistance, an old man of 70 years sure appreciates people like yourself to help get us through.
    The problem just started last week and i have owned the new monitor for 3 months, hooked to the same computer, mac g3 350 and it worked perfectly up until last tuesday, started computer and "imput not supported" dances across the screen, for about 30-45 sec until the computer is loading the HD, then it comes on and acts normal.
  • 109 Answers
Your video card is not compatible with your monitor...
Posted on May 10, 2010
Monitor imput out of range
screen resolution set to high start in safe mode select 800 x 600 at 60 hz save and restart if vga cable is detachable replace cable and check for bent pins
Mar 09, 2013 | Hannspree I-inc Il195abb 18.5in Vga Led...
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
The screen says imput not supported but I can hear the startup sc
You need to set your PC video resolutiotn to the native resolution of this monitor, 1440 x 900 @60Hz. You get the message because the old setting for your old monitor (crt?) is too high for your Acer. You may have to hook up your monitor and set up the new resolution. Or you boot up in safe mode, set the resolution to 640 x 480, reboot into regular mode, reset the resolution again to be 1440 x 900 @60Hz
Apr 04, 2010 | Acer V193w LCD Monitor
Monitor green light comes on then it says no imput
looks like there is problem with ur signal cable check that monitor signal cable is tightly fixed or contact ur product support center.
Mar 31, 2010 | HP Pavilion F1523 15" LCD Monitor
GTA IV problems
try in game option a small resolution
Mar 07, 2010 | Acer AL1716 F Monitor
Computer screen says imput not supported what do i do?
i believe at boot you should hold f8 for advanced booting options, and then select safe mode, which will start the computer in a lower resolution graphix. from there, set the resolution down on the display. right click on the desktop and select properties or personalize, then look for the display setings for screen resolution. its prolly set to 1680 x 1050, and needs to be set to something around 1280x768 or something: maybe its set to a different aspect ration or just plain different size.
Oct 09, 2009 | E-Machines eMachines Monitor E15T4
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
"Imput not supported"
What resouluton is your video card set at? check the specs on the monitor and set the proper resoulution and or refresh rate good luck
Apr 22, 2009 | Computers & Internet
'input not supported'
First install another monitor so Windows will load.
Then right click on "My Computer" and select "Properties", then click on the "Hardware" tab and click on "Device Manager" button. In the list and click on the "+" sign next to "Monitors" then right click on the monitor in question and select "Uninstall", then click "OK" and close all windows and "Shut Down" your PC. Install the monitor in question again and start your PC and wait 10 minutes or so and XP will set up the monitor like it's the first time you installed it.
I hope I understood your issue and Good Luck.
Apr 08, 2009 | Acer Aspire 3680 Laptop
Acer X193W LCD Monitor Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
