Question about Panasonic FP-D250F Copier
Panasonic photo copier what does E01-22 error message mean
    Champion:
  • 224 Answers
The polygon motor is at fault, this requires a service technician.
Posted on May 11, 2010
Panasonic DP-8020E error message U15. What must we do?
Two weeks back change developer and toner powder. Now printing quality is very dull means printing quality is light
Jan 19, 2011 | Panasonic DP-8020E Black and White Copier
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray #2. You will not be able to use your tray #2 until it's fixed. You can check it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
May 07, 2010 | Panasonic DP-C213 Color Copier
What does error message E-01 01 mean on the Panasonic FP-D355 copier?
the optical unit scan drive is not working, try switching off and on, this may reset the problem, if not i'm afraid its a technician thats needed.
Mar 09, 2010 | Panasonic FP-D355 All-In-One Printer
I get an E140 error message when I turn on the copier
Hello sir; The error code you display it means optics fan not working you have to replace it.
Aug 28, 2009 | Panasonic FP-7735 Black and White Copier
Panasonic DP-8045
it means that your finisher staple motor jammed. try to remove the staple cartridge and anything that might make the staple not to move.
Aug 20, 2008 | Panasonic DP-8045 Grayscale Copier
Panasonic DP-190 Error Message
E01-31 is a scanning lamp error"does not turn on. possible solutions. scanning lamp cable defective.
spc board or sc board is defective
Jan 03, 2008 | Panasonic DP190 All-In-One Laser Printer
Error message on copier
That is a laser unit error. If resetting the machine's power doesn't clear it up, then it means the laser unit is dead/dying. If that's the case, your only choice is to replace the laser unit.
Oct 04, 2007 | Panasonic Workio DP-150PA Copier
96 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
