Question about D-Link DIR-625 (790069292637) Wireless Router
Connection issues i can access the internet on my laptop via ethernet cable, tho when i connect to the d link it says that the connection strength is strong, but it says i have limited access. And i can not get on the internet or use anything that requires the internet.
  • 264 Answers
To troubleshoot the issue follow the below steps
1.Try disbaling and enabling the wireless lan card
2.Check whether Ip addresses assigned in the wireless network card.If the address is assigned by dhcp and not assigned in network card means assign static ip in the range supported in the networkand ping the website or gateway.
3.If the ip is assigned already means try pinging the gateway and dns server .If ping is success means the connection between router and pc and internet is good .In that case you have to check whether authentication is successful if any authentication is used.
Posted on May 10, 2010
I have an issue with Wireless Access Point D-Link DAP 1155 When i'm connected to the internet via WiFi by mobile device (different ones Galaxy Note 1, Galaxy Note 2, Galaxy ACE) when browsing internet is...
Do other wireless laptops connect to your wireless router, and give good speeds? Do you have many wireless networks, other than your own, that show up when you try to connect? It could be interference from other wireless networks in your vicinity.
Aug 21, 2013 | D-Link Computers & Internet
Tip
Troubleshooting Laptop WiFi Connectivity Issues
Most laptop manufacturers provide an external switch to switch on/off the WiFi functionality. As a result, the first problem most new laptop owners encounter with trying to connect to a wireless network is that their WiFi has inadvertently been switched off. So, if you have a WiFi connectivity issue, the first thing to make sure of is that your laptop's WiFi external switch is on.
The next most common problem when it comes to WiFi connectivity issues is that the signal strength is too weak to hold a connection. This can be extremely confusing if the network is working fine for a person sitting at the next table. This could be due to several reasons. This person's laptop might have a more sensitive WiFi receiver, be set in just the right location where the signal strength is maximum, or even be accessing a different WiFi network other than the one you are trying to connect to. When you're troubleshooting a wireless connection, make sure to get as close to the router as you can, certainly in the same room if it's in your own home, so you can eliminate signal strength as a possible issue.
In order to prevent every stranger who walks by from accessing any network with WiFi capability, there are a number of security options that can be set on WiFi routers. The most common of these is simply enabling password protection, so that any laptop trying to connect to the network will have to provide a password for the initial connection (after that the operating system remembers the password). In order that you be able to connect to a WiFi network, you will have to set up your laptop's WiFi connection with the correct key. First, try the key printed on the router label, but if a custom password was created when the network was set up, you'll either have to find the piece of paper where it was written or chase the person who set up the network. If the password absolutely can't be recovered, search the Internet for how to reset the router (varies with brand), create a new password and enter it on all the computers that use the connection.
In some cases, it's easy to reset the password or turn the security on and off by connecting directly to the router with an Ethernet cable and typing the fixed IP address for the router into your browser.
Connecting directly by cable to the router is an important troubleshooting step for wireless connectivity even if you don't have a password problem. If you can't connect to the Internet even after plugging directly into the router, neither the wireless adapter in your laptop nor the wireless transceiver in the router are at fault.
If you plug directly into the router via the Ethernet cable and you gain access to the Internet, you can continue troubleshooting wireless issues. Check Device Manager to see if it's complaining about the network hardware. If not, and you still can't gain access at this point, the problem is either with the high speed modem and ISP, or a networking software issue within the operating system.
High speed modems, often called routers if they include a built-in router, are equipped with a series of status LEDs that can be used to diagnose many connectivity problems. Whether you have a cable modem connecting to the cable company, DSL via the phone company or one of the more esoteric high speed modems, they should always include an LED that tells you if the connection between the modem and the Internet has been established. If this link light is out, or has changed colors, say from the familiar green to an ominous red, power down the modem and turn it back on again. This hard reset will usually fix dropped connection problems caused by storms, power surges or signal interruptions, providing the modem hasn't been damaged. A modem/router will also include a status LED to show whether an Ethernet cable connection to your laptop is good, and your laptop will have a little status/activity LED for the network connection as well. While color coding isn't universal, solid green usually indicates a good connection, and blinking green or orange usually indicates activity. Some modems include an LED to tell you if the DSL or cable link to the ISP is good even when the Internet isn't functioning.
Operating system issues affecting connectivity can include firewall (security software) settings that prevent your computer from establishing communications with the Internet Service Provider (ISP), or the failure to install the software that ISP requires. Unfortunately, there are also more complicated problems that will require drawn out conversations with the ISP's technical support department to troubleshoot.
If you're adventurous, or desperate, you'll find all sorts of third party software online that will reset the Windows stack or change registry settings back to defaults, but you're better off trying the tech support route first if a software glitch is at the bottom of your problems.
Please Vote for this Tip if you found it helpful.
M. Omran
on Oct 25, 2010 | Computers & Internet
We have cable internet provided by Virgin. I am accessing the internet by plugging the ethernet cable dirctly into my laptop rather than via my DI524. Have just read a post that says I have to be connected...
If you can connect to the internet using the Ethernet cable on your laptop then the cable modem is configured correctly.
If you want to connect to the Internet using the D-Link wireless router then first you need to configure the D-Link wireless settings and then configure the wireless card in your laptop with the D-Link's wireless settings. Remove the Ethernet from the laptop and connect it to the WAN/Internet port on the D-Link wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 13, 2011 | D-Link AirPlus DI-524 Wireless Router
My wireless network connection status in connected speed is11.0 and my signal strength is good but I cannot connect to the internet
Are you running any Internet Security software such as Norton? Also make sure your wireless router is actually connected to the Internet, just because your laptop is connected to the router doesn't mean the router is connected to the internet.
If you can, plug your laptop in to the router via an ethernet cable to make sure Internet access is working, alternatively if you have another computer connected to the router check the internet access on that one.
Also try doing a soft reset on the router, just disconnect from the power for about 30 seconds, reconnect, wait one minute then try again.
Jun 26, 2010 | Computers & Internet
No wireless connection
Dont enter the Router IP as WWW.192.168.0.1, Instead just type 192.168.0.1 and it should let you access the Router EWS Page. you are trying to access Internal network ( which we can call local network or LAN ) so do not use WWW.
In the Address bar of Internet Explorer, just type the IP Address.
Jun 24, 2010 | D-Link AirPlus DI-524 Wireless Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
Belkin Wireless Router
1. you need to put the software belkin installation disc into the girls laptop not just the desktop.
2. you need to plug the modem back in
3. on the back of the router press the little button NOT THE RESET BUTTON MAKE SURE IT IS THE LOCK BUTTON it will ask you for a password on the laptop
May 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
D-Link DIR-625 (790069292637) Wireless Router Logo
160 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
