Question about Panasonic Televison & Video
I have a Panasonic TV Model PT-53TW536 that has no picture and no sound. The power light comes off and on. Any suggestions as to the problem? Thank You!
  • 375 Answers
SOURCE: Panasonic PT-47WX42F
go to servicemanuals.net
Posted on Sep 06, 2007
  • 54 Answers
SOURCE: NO PICTURE, NO SOUND, TV TURNS ON THEN TURNS OFF
maam\sir,,,i think theres something wrong with its power supply,,,kindly chect the power supply section of your tv,,,thnksss and hope to help you,,,!!
Posted on Jan 29, 2008
ladywinn
  • 5138 Answers
SOURCE: panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Posted on Feb 05, 2008
SOURCE: Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Posted on Oct 11, 2008
jerryg50
  • 1667 Answers
SOURCE: No picture or sound
Make sure that there is actualy power going to the AC power source where the TV is plugged in. You can re-set the TV by disconnecting the power for about 10 seconds and then connecting it back again. If the set still does not start it will require service.
If the set is dead it is most likely the main power supply board that failed. The service tech would replace the power supply and also investigate to find the cause of the failure. Sometimes another board could have a failure and cause the power supply to be damaged.
If the set will not start up, it will require shop service. You can call Panasonic tech support to find out the authorised service rep for your area. Check to see if the set is still under warranty. If not, it will be expensive to service.
Jerry G.
Posted on Jan 17, 2009
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
Panasonic PT-61HX42F turns on, but wont stay on.
you need to change the stk 392-110 (2 ic ) and some resistor around the area ok
Sep 08, 2008 | Panasonic PT-61HX42 61" Rear Projection...
Jul 13, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
