Question about Brother HL-2040 Laser Printer
How to clean printer drum - Brother HL-2040 Laser Printer
    Sergeant:
  • 144 Answers
Follow the steps
1. Remove the drum
2. Disassemble the drum
To disassemble the drum you'll need to remove the E-clips from the bar holding the photosensitive drum in. Do this with a smll precision screwdriver. Insert it in the space between the e-clip and the bar and twist it to push it off of the bar. Be careful not to lose these. With these removed, gently pry off the pieces underneath. The bar should slide out now. With…
3. Clean the parts with a brush
4. Reassemble the drum
5. Test for a print
Kindly rate my help+ Thank you.
Posted on May 10, 2010
What do i clean the drum with clean cloth or acholol
In most printers with a drum (I assume this is a laser printer) it is a user replaceable but, not a user serviceable part. You may be able to order a replacement drum but, you should not attempt to clean or otherwise service the printer drum.
Jan 01, 2013 | Office Equipment & Supplies
Printer is dsplaying"drum error" to
According to your problem, may be the drum is not usable now. But first clean the toner drum properly. May be this may occurs for setting of the drum in printer. So resets the drum carefully inside the printer after clean it. Then reboot the printer and the system both. If it doesn't solve your problem then change the toner. It may help you or you have to change the drum or cartridge.
Jun 27, 2011 | Brother DCP-7040 Laser Printer
How do you clean the drum
Hi
Just open your drum and take the tissue and clean the drum and roll the remove the black cartridge powder to drum clean the put again... this is very simple way to clean the drum...otherwise u have to chose the HP service center also.
May 13, 2011 | HP CP3525N Color LaserJet Printer
Can't print the printer is giving drum error
Please follow these steps to solve the your problem.
1.Open the front cover ofthe printer.
2.Remove the toner assembly
3.Separate the toner & drum assembly by pressing the blue leaver .
4.Take the Drum assembly and clean it properly with a soft ,clean cloth.
5.There is a thin wire (Carona wire) clean it properly.
6.Clean the Glass roler carefully(OPC)
7.Then fix it again with the tonner & insert it to the printer.
Try it if not solved then replace the Drum.
Dec 08, 2010 | Brother HL4040CN Laser Printer
Is there a way to clean the drum on the HP laserjet p3005n The toner and drum are one unit.
You don't want to clean the drum. It is done automatically as the drum rotates. The cleaning blade scrapes the residual toner off of the drum.
If the drum is not getting clean then you have to replace the cartridge.
Feb 10, 2010 | HP LaserJet P3005n Printer
How do i clean a brother printer drum?
You don't clean the drum...you replace it, and the problem is solved
Apr 21, 2009 | Brother DCP-7020 All-In-One Laser Printer
Clean printer
open the front panel and remove the toner and check for any kind of scratches on the toner drum it might be of green color and if you found the scratches on the drum that mean drum has to be replace. if its not so than clean that drum properly by soft cotton and reinstall it and check the print.
Dec 23, 2008 | Brother HL-2040 Laser Printer
Print smears
Hi Allan:
Sounds like you need to replace the drum pivot plate assembly. This assembly is what cleans the drum assembly prior to putting the image on the drum. The pivot plate assembly has a rubber drum cleaning blade on it and when the printer begins to print a page it cleans the drum first. If the cleaning blade or the pivot plate are deffective then the drum will not be cleaned properly leaving smudgy areas on the drum.
Aug 13, 2008 | Xerox Phaser 8560DN Laser Printer
Dell 3000cn drum cleaning?
Do not try to clean the drum. The drum and its asociated cleaning blades and other parts, are COMSUMABLES that have a certain useful lifespan, the same as batteries or automobile brake pads. When smudges appear on the drum, it and the associated parts are at the end of their useful life. Order a new IMAGING DRUM KIT from www.dell.com
Aug 06, 2008 | Dell 3100cn Laser Printer
How do you clean the drum?
Brother had me take a tissue and wipe the drum. You can spin it with the gear on the left had side of the drum. Then they had me slide the blue tab 30 times back and forth.
Also take a soft cloth and clean the lens on the inside of the printer. First take out the drum unit. The lens in toward the back.
Feb 27, 2008 | Brother HL 1850 Laser Printer
Brother HL-2040 Laser Printer Logo
470 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
