Question about Midea WP10000 Air Conditioner
We have a Midea Model no MSX-24HRDN1-QCOW, purchased last year. Can you please advise how to switch the split wall system to heat ? Our email is hbw@chariot.net.au or ph no is 08 8266 5555, fax 08 8266 5511, thankyou kind regards Jenny
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Hi Jenny,Pressing the mode button on the remote until it display HEAT or a sun or an arrow next to heat or a sun will indicate that it is in heat mode.
Hope this helps I take the time to help you so please rate me
Posted on Jun 28, 2010
Manual for garrison oil heater model #043-5863-4
You should be able to download a manual here:
garrison oil filled heater model 043 5863 4
Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
Nov 16, 2016 | Heating & Cooling
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
New Midea Air Conditioner system 3, does not seem to get cold air. Mode is on Cool and fan speed increase. Temperature at 20 degree.
More info needed. Is this a one-piece unit or a mini-split? Model number, any error codes, etc. More info will help
Jan 03, 2015 | Midea Heating & Cooling
Thank you for your help, I have a used mitsubishi mini split system heat pump model #mxz2A2ona-1 serial #7002621T and installation manual SG79T694HO1. I need the manual ASAP please on this entire unit,...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Apr 14, 2011 | Heating & Cooling
I have a blizard split model 10.5 years old in a caravan. model sa101 the air feels cooler but seems to have no noticable difference in actual temperture and compressor seems to run continuously ...
Please understand first, air conditioning system not only cooling the area but also removing the heat. If heat in the room stays constantly, even 24 hrs running a/c couldn't cool the room.
Now, why the a/c could not cool the room or remove the heat from the room.
Check air filter, evaporator coil and blower wheel for clean. If not service the unit immediately. And also check indoor fan motor rpm. If rpm is low, replace fan capacitor. Check for gas pressure to confirm no leak or running with short of gas. It's advisable to service both indoor and out door once in 6 months at least. Otherwise, your electric bill will kill you lot. Thanks.
Jan 31, 2011 | Electrolux Heating & Cooling
What does a df error code stand for on a con-air heat cool split system wall mount
Friend!,
Please ensure with your model/brand and error code. To my knowledge and web search, I don't find tour model on market. Don't be angry, plz check once again and write back.
Dec 15, 2010 | LG LSC183VMA Split System Air Conditioner
DVD eject does not work. DVD is still inside but door will not open? Please advise on course of action. Thanks
1. Please reset the unit by unplugging it from the wall for 2-3 minutes.
2. If problems persist please email Toshiba Customer Solutions Department at Customer_Support@tacp.com.
Please include the following information in your email.
Name
Phone Number
Full Address
Model Number
Serial Number
Date of Purchase
Issue with unit
Sep 16, 2010 | Toshiba DR410 DVD Recorder
Problem of Midea dishwasher WQP12-9240A
yOU SHOULD BE ABLE TO USE THE SERIAL AND MODEL NUMBERS. The factory technician will ned those at the least.Look up the Midea on the internet and get the factory rep to explain the warranty or the dealer you purchased the unit. Good Luck
Jun 01, 2010 | Midea MPM-08CR-BB4 Portable Air...
Hi, I have a wall mount midea split a/c model- MSG-36HR that will only heat. when put in cool mode it only blow's room temp air and the outdoor unit won't run. On heat mode it works normally. I have cycled...
Most heat pumps are 'fail-safe to heat'. That is: the normal position of the valve which reverses the function is in the position which provides heat. The reversing valve must be powered to switch to the cooling position.
Although the lack of valve function could be a mechanically defective reversing valve - it's more likely to be an electrical issue. Start with checking for power at the reversing valve's coil. If it's powered unpower it - you will be able to hear the reversing valve distinctively
Oct 03, 2009 | Midea Heating & Cooling
Accidental Hard Drive Deletion - Please Help
you may try to go to esupport.sony.com and download the file rescue program for memory sticks. you will need a memorystick model number and serial number to download it. try this: MSX M1GST(model name ) K422L1L(serial number) email me me if you want me to walk you through.
Feb 26, 2008 | Sony Handycam DCR-SR40 Camcorder
Midea WP10000 Air Conditioner Logo
197 people viewed this question
Top Midea Heating & Cooling Experts
Steve F
Mike
Shehu Pro
Shehu Pro
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
