Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic PT-47wx51 memory question?
Does anyone know what the different memory locations (1-8) are for? I accidently copied number 1 to 3 or 4 (cant remember which!) and now when I am in the convergence menu with a 1080p input applied I cannot get the correct number of horizontal and vertical lines on the grid, also cannot get the lines that are there to be straight. Any help would be appreciated
  • gingy900 Apr 10, 2008
    I was just trying to converge the set, no problems, now it is converged fairly well but the vertical lines on the edges have a slight curve and the top and bottom lines also have a slight curve. Dont fix it if it isn't broke!
  • gingy900 Apr 11, 2008
    Yes I can do the adjustment beyond the edges of the screen. I think I messed it up when I copied the memory from location 1 to 3 or 4, do you know anything about the memory locations? Can I copy from a higher number back to 3 or 4. I found a post on one of the forums that was talking about copying from 1 to 5, 2 to 6, 3 to 7 and 4 to 8. I was wondering if I could copy from 8 to 4 as they appear to be backup copies, but I dont know and hate to make it worse.
    Scholar:
  • 170 Answers
What was your original problem?
Posted on Apr 09, 2008
  • Scott Henderson
    Scott Henderson Apr 10, 2008
    in this adjustment menu, can you go past the edge of the screen? if so there is an adjustment there, you just can't see it.
  • Scott Henderson
    Scott Henderson Apr 11, 2008
    don't copy anything in memory enless an autherized service tech has said to do so. adjust your convergance and be done.
    if you copy or go into the wrong area. you will have a fish tank.
    or you will have alot more time, and i'm talkin days of working with service adjustments if you mess it up by copying.
    if you mess up the eeprom then you may have to replace a board if you can't adjust it out.
My tv won't power on, it blinks 3 red light, what does this mean?
in panasoni tvs each number of blinks reprents a genral ida of what is wrong with it so that the technician know where to look in this case it is the convergence ics nowyou can order them yourself but i do not recommed it as these are very sensitive chips call your local tv repair gys and youll ger up and running either that day or within a couple days,
Jul 01, 2010 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX49 similar to other models?
What is your model number? Most of these sets use the same parts--if a convergence problem I have start to finish instructions for this repair.
if you want them rate this solution as I do this here for free.
sd tech
Dec 21, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Pt-47wx51
Value of both is 0.27 at 1watt
Jul 19, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Help please
Conergence amp ICs are bad and quite possibly the resistors that power them
Feb 23, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Need part # for convergance IC chips
they should be stk392-110. if you look in your set they are located on the left side of the chassis on the huge heatsink. you can get the numbers off the ics its big enough to see. you can get them at the following link for about 9.00
http://www.yahoo.com/
Dec 28, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic pt-50dl54j
The 3 times LED code points to no fan rotation. There are 2 fans. Check the larger fan first, p/n = FBL12G12LS, located near the lamp. Even though that fan may be rotating, it may be slow.
thanks
scott
Dec 20, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX51CE convergence
the value of r7050 is 2.2 ohm 2W
i might be able to email the manual but its big - just let me know and i will send it or look up anothe part # for you
thanks
scott
Sep 29, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Convergence IC's
This Company has them http://www.mcminone.com/,when the search window comes up you need to put in stk392-110 and the price will come up.
Oct 11, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Pt-47wxs1ce green wave at bottom of screen cannot adjust green convergence
you have bad convergence IC's and possable 1 bad resistor
let me know and i will help you find them in the set if your are a good solderer - or call a tech
thanks
scott
Aug 30, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
