Question about IBM ThinkPad T20 2647 Notebook
T-20 2647 think pad
Hello, my t-20 starts and runs for about 5-10 minutes then shuts down completely. could it be the heat sink?---or fan? thanks for any help you can give.
THANKS
  • Anonymous Aug 03, 2008
    My T20 suddenly "died", black screen, 1 diode shining. After a certain time, it can be started again, than is working cca 8min and than dies again. When started again immediately after this, it does not start or does the same after a short time. No beeping on start. Fan assembly looks OK, fan is shortly working on start. This is with W2K, but Linux live CD is the same. According to MobileMeter CPU temp is 39oC, HDD 41oC. Please any suggestion? THX a lot.
    Sergeant:
    Champion:
  • 277 Answers
Possible... run your unit in safe mode then observe it...if happens again check the memory ram... if not your hard disk is infected with virus...try scanning /cleaning drive c:
Posted on Mar 28, 2008
My x205-s9349 toshiba laptop is getting hot in the area of #1 hard drive and shuts down. I have vacuumed the case out and still does the same thing. this laptop has run hot ever since it was new.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this. Use a fan assisted laptop cooling pad for addition cooling.
May 29, 2011 | Toshiba Satellite X205-S9349 Notebook
Thermal shut down on Gateway 500r
Have you checked whether the CPU fan is working or not
Sep 27, 2008 | Gateway 500GR PC Desktop
My dell latitude D610 laptop gets heated up after a few minutes I the start the laptop and eventually shuts down.
  • There is a possibility that the fan of your laptop is not working. Make sure when you power on the laptop the fan is running. And if the fan is not working replace it so that your laptop will not heat up and it will not shut down.
Feel free to reply this solution if you have further questions. Thank you.
Feb 14, 2011 | Dell Latitude D600 Notebook
I have an hp notebook... model no cq50 106au.... of late my note book can run only for about 15 minutes and then shuts down. i think its due to processor over heating. anyways i gave my laptop to the HP...
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jan 13, 2011 | Compaq Presario Notebook
My DG965SS mother board just shuts down when it want to. Some times it will just reboot right in the middle of whatever and some times it tries to reboot but freezes on the start back. I have reformated...
Hello
I have a intel dg33bu.Have a look at the internel fans.Are they clean.
The processor fan and heat sink need to be clean of dust and dirt.
Last- It may be a good idea to put some fresh thermal paste on the processor.
What you are describing sounds like a heat issue,runs,heats up then shuts down.
Sep 11, 2010 | Intel DG965SS Motherboard
Power
If the fan is spinning quite fast then the overheating problem is most likely dust clogging the fan and heat-sink assembly. Blasting air into the fan and heat-sink can only make it worst as you are forcing the dust further into the heat-sink fins.
Remove the panels covering the vent and fan/heat-sink, loosen the dust and vacuum to remove this dust off the fan and heat-sink. Check the fan to see if it spins freely, if not replace the fan.
After re-assembling and boot up, if you still have heating problems, addition cooling can be employed by purchasing a laptop fan assisted cooling pad. Place the laptop on top of this pad and the fans on the pad will direct additional cooling air to the laptop's vents.
Mar 08, 2010 | Gateway ML6732 Notebook
Acer aspire 5610-4654 keeps shutting down
Did you noticed overheating (hot laptop areas, fans spinning like in crazy?)
Can you start the laptop again just after it shuts down itself??
Jan 18, 2009 | Acer Aspire 5610-4648 Notebook
Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Jul 22, 2008 | Computers & Internet
IBM Think pad T22 problem
Hi
Check your laptop CPU fan is running if no replace it. Problem is because of over heating....
Thanks
Jul 10, 2008 | IBM ThinkPad T22 2647 Notebook
R40 think pad laptop fliking
Right click on the desktop and go to the properties option.Click on the Screen Saver Tab and will find Power option . Click on it and check the power schemes6112293.jpg
Jun 19, 2008 | IBM ThinkPad R40 2897 Notebook
IBM ThinkPad T20 2647 Notebook Logo
141 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
