Question about Nokia 6300 Cellular Phone
My phone not getting signal properly when a signal low area.some time even is signal available,cant take call to phone.
  • 2,069 Answers
Thats a hardware problem, your RF amplifier should be weak. it is responsible for amplifying and mentaining the signal on your phone. you should therefore take it to a service point so that they check it anf if possible replace it.
Regards
Posted on May 10, 2010
Sgh-d407 no signal
Samsung SGH-D407 Flip Phone: No signal
Hello. It's possible that your cellular service area that you are located in, has low and limited connection available..
Call your service provider on a different phone to let them know that you are not getting service in all the areas you've tried. Indicate how far away from each location that you are unable to get signal from. If you can not get signal anywhere at all, this should also be addressed. They may even walk you through resetting your APN settings
In some cases, it could just be the building that you are located in that is blocking cellular service.
Sometimes, it could be a fault of the service provider. They may need to reset your connection on their side. If not, at least you can get them to try..
Other things you can do:
1) On your device: Make sure that your SIM card is perfectly sitting in its tray and on the connectors..
2) On your device: Make sure that your mobile cellular connection is enabled
3) On your device: Make sure that airplane mode is not enabled
Jan 27, 2016 | Samsung Cell Phones
How to increase connectivity and strength of 2G and 3G network
@Surendra
It's based on dBM and asu and not the bars you actually see. Even if you may see fewer bars you could have equal quality. The phones, based on different OS may be calibrated a little differently. It's best to contact your service provider and verify....
1. Your SIM is properly programmed.
2. Your PRL is updated
3. You have a recent SIM
Mark
Motorola Support
Nov 04, 2014 | Motorola Mobility XT912 Droid Razr Verizon...
What do i do when my mobile phone says 'mobile network unavailable?
The ideal solution temporarily is to find a spot with wifi.
The "network is probably not your phone's problem. Its either the network having problems or your location.
The problem is that u cant get a proper network at that place. In your phone, come to the home screen, where wallpaper & other options are displayed. There'll be two indicators, one of your battery, & the other, of the same style & behaviour, the network indicator. That tells you about your signal strength.
First, restart your phone, it'll refresh the network. If there's still a problem, then it means that u cant get a proper connection to that network. Then what u should do is- If you're in a crouded area, or in a room, go out in the open. Or if you're in a village, then you cant find signal there easily. But rather travelling for good network, you should use someone else's phone which can get signal or a landline. Or if you want signal, you'll have to travel to some distance, or maybe even a long distance. That's all which can be done.
Jul 31, 2014 | Samsung S5830l Galaxy Ace Black Unlocked...
I cant hear the other person in my samsung rex cell phone what is the error
Make sure that the signal reception is good & try to increase the in-call volume , if that does not help, its time to send the cellphone back to service center.....
Mar 27, 2014 | Samsung star II duos GT-C6712
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
Oct 31, 2011 | Nokia Cell Phones
Caller ID does not display
CID needs 3 things, a subscription from your phone line provider, a phone to display it, and someone sending it.
If your generic phone is of the single line set variety and it has CID, then check with your provider. If it's a system phone, it may not have the proper equipment installed or not even be available in the phone system. Usually, even if the call is blocked by the sender, you will get a date and time and "unknown caller" or "out of area"
indication when a call comes in.
Carl
May 17, 2009 | Uniden Cordless Phone
Does't connect to network - search Network
Hi
It sounds like you may have a poor 3G reception in your area. Even though other O2 phones are working better they may be running on the 2G masts in your area.
Try in setting/network menu turning off 3G reception, that way the device will only look for 2G masts. Your handset will give priority to 3G masts where available and sometimes will hold onto the weakest signal making poor call quality, and or dropping connection.
Advantages to using 2G only = better standby and talk time / better reception where 3G is poor.
Disadvantages = Slower web browsing / no video calls.
WEP / WPA will only apply if you are connecting using WI FI and have nothing to do with your mobile network connection.
Hope that helps?
Apr 27, 2009 | O2 XDA Flame Smartphone
LG SHINE KE97-Terrible Reception
Call your cell phone provider and they may make a satelite adjustment for the areas you state that are weak.(see if they tell you that your the first one to tell them this about the weak signal)
If they cant help ,get a better phone that will get the signal you need. Please Rate This !!!!!
Jun 11, 2008 | LG Shine KE970 Cellular Phone
VERY WEEK NETWORK IMEAN SIGNAL VERY LOW
Network signal strength is not based on your phone. It is based on the network. Poor sigal is their problem, Call them. If this rates as helpful, please post as such.TY
Sep 11, 2007 | Siemens SX66
Nokia 6300 Cellular Phone Logo
126 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
