Question about Brother MFC-440CN InkJet Printer
Keeps asking for new cartridges when new ones have already been installed Says no cartrdige cyan but all cartridges are in place
  • 2 more comments
  • bobdunn2 May 10, 2010
    The machine keeps saying ink cartridge empty although all four have been replaced. It is asking for cyan. I cannot acsess the menu to reset as last adviser recommended. I have also turned the machine off and on to try and cancel the message
    Unfortunately this is not the answer, we have installed many cartridges and our machine i scertainly not dirty!! Anyother ideas?
  • bobdunn2 May 11, 2010
    printer continually asking for cyan inke jet even though new one has been installed. All inkjets have been removed shaken cleaned etc.
    Can it possibly in the memory of the printer and needs to be overidden?
  • 12,061 Answers
Http://welcome.solutions.brother.com/bsc/public/as/as_ot/en/doc/manual_index.html?reg=as&c=as_ot&lang=en&prod=mfc440cn_all&dlid=&flang=English&type2=-1
user manual above http://www.fixyourownprinter.com/forums/inkjet/47889 helpful site.
http://www.cheapservicemanuals.net/samples/MFC_2_SAMPLE.pdf Service manual above.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000087/faq002487_000.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=16
The ABOVE link, directly addresses this issue and a FIX. Below is FYI, it may help in later problems.
Cover your cartridge with black tape. At the back of the cartridge (transparent square). Then your ink will show full tank.
Posted on May 11, 2010
    President:
  • 4,070 Answers
Hi! Have you removed the protective covering of the ink cartridge? Theres a protective covering at the bottom of the cartridge that needs to be removed. It may be the reason thats why its not being detected. Try to clean the well where the cyan sits, it may be clogged by dried inks and may cause the problem too. HOpe this helps and have a good one!
Posted on May 10, 2010
  • 6,487 Answers
Try first taking out all the cartridges that you have on the machine and then shake them a bit and also clean the tip of those cartridges with a isoprophyl alcohol to make sure nothing is blocking there.
  • 4,924 Answers
Yeah ,,this is happening when you change the certridges and do not reset it ...usually it do not happen with new ones ..but if you just filled them you have to go in the menu ..and look for counter reset and reset all couters..specially the ink or the drum ...if you have general reset to default settings is better ...
anyway you may take out again ...shake them and fix them well...after that press reset button and keep it for 10 seconds ...also look in the menu if it has reset ....if no reset is present on this model ..just power off..and when you open it ..keep the button pressed ..For some models this way is the reset ..at least will cancel the jobs and look for the cartridges again ..
  • Catalin Turcu
    Catalin Turcu May 10, 2010
    you really have to seek for away to reset the printer in order to accept the cartridges..
Installed new cartridges into HP Officejet 6500 and the cyan and yellow don't print. Alignment keeps failing
takeout the cartridge and clean the coper dots..then dnt put them in..power on the printer...while pressing # 6 button disconnect the power cable....while pressing then reconnect the cable...after some settings it will ask for the cartridges...put them in..it will do the need full
Mar 24, 2010 | HP Officejet 6500 Wireless All-in-One...
Trying to load new ink cartridges and the machine wont recognize one of them. It just keeps asking us to load CYAN? Your asssistance please.
the chip may be bad. did u buy genuine toners or imitations?
either way u should be able to get a replacement from the place u bought them, it is common problem.
Feb 28, 2010 | Brother DCP-7020 All-In-One Laser Printer
After installing new ink cartridge. my multi purpose offic jet 6110 keeps saying "failed to align cartridges" though the cartridges seem to be installed properly. any ideas?
HI
try removing all the cartridges and restart the printer ,it will ask to install the cartridges,install them one by one and then see if it prints an alignment sheet,if it doesnt print it this way there is an option to align print cartridges in the printer drivers, goto the control panel--->printers and faxes--->rt click the printer icon and goto properties,under properties there should be an option for either maintenance or service this device button,when you click it ,it gives an option fro aligning the cartrdiges,
Jul 14, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
I changed my cyan ink
That definitely sounds like the cartridge isn't registering properly. I would take the cartridge back to where you bought it and ask them to exchange it with a new one. This can happen from time to time.
If the printer was new out of the box, contact the manufacturer for a replacement cartridge. You can reach Brother here
7777 North Brother Blvd.
Bartlett, Tennessee 38133
1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
9:00am to 8:00pm Eastern Time
Apr 28, 2009 | Brother DCP 130C All-In-One InkJet Printer
Printer keeps asking for a new cyan and Ive already replaced it!!
i don't have this model but mine did do this the area where the ink comes out is clogged try running clean ink heads if that don't help you will need to do it manually with a qtip and alcohol just don't press very hard might damages the printer read pins. If this fails you may need to take it to a repair place and have the head cleaned
Mar 16, 2009 | HP Photosmart C6100 All-In-One Printer
The new light cyan cartridge was not printing...I thought it may be faulty so purchased another which also did not work. I did 'clean print head ' several times followed by nozzle check. All other colours...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Inkjet cartridge
Cyan is the blue color cartdrige. It is placed where all carts are placed;-)
Feb 02, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC-420cn printer says install cartridge. But there is a new one just installed.
by useing original brother carts instead of poor designed generic ones.
Or by answering the lcd-display question if you have changed the cart.
or by making sure that the plastic nose secures the cart which was placed well into the holder.
If that doesnt work, the circuit board might be defective.
Jan 09, 2008 | Brother MFC 420CN All-In-One InkJet...
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Brother MFC-440CN InkJet Printer Logo
125 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
