Question about Blitz BZC5K Car Component System
How do i install my component set if i had speakers already?
I am switching from just a 5 1/4 in each door to the component set
    Scholar:
  • 47 Answers
The mid-bass drivers usually can fit easily into the original speaker holes. Pre-wire and double-sided sticky tape the crossover block to a cross-beam or structural support inside the door- NOT on the exterior sheetmetal. Choose a mounting location for the tweeter pods. Usually around ear level, or aimed at ear level works best. I like to tuck them up on the A pillar of the vehicle frame and if no room is available there - the plastic molding on the interior door where they hide the mounting hardware for your side mirrors is a prime choice too.
Posted on May 10, 2010
Going to install component speaker in my suv plz help me where to install front door or rear door also have a sub woofer in tail
go to crutchfield.com and look under their car audio installation page. From there you will have to input your vehicles year, make, and model. It should give you detailed instructions on how to properly install your speakers. You could always look that info up on the general web, but I find crutchfield to be a lot more informative.
Mar 19, 2015 | Car Audio & Video
Hooking up speakers
first off stock wiring for speakers,and or amp are with minimal wiring.Rewire system for better sound quality,also use noise suppresors if needed.
Jan 18, 2014 | Toyota Cars & Trucks
I have alpine sps600c & am installing them in a 2001 Nissan frontier w/ 6 disc 6 speaker (2 ea in each ront door, 2 in back (crew cab). Do I wire my tweeters to existing tweeter output, or...
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
Sep 05, 2011 | Alpine SPS-600C Car Component System
I need to know what I will need when installing Focal 165 A1 6 3/4 speakers in the doors of my 2003 Nissan Altima. (speakers adapter rings ect.?)
When putting in a good set up speakers like those, I always recommend:
Making mounting rings/plated for them
Sound Deadening Material to help seal the door up for better bass from the mids
Gasketing Foam to help decouple surfaces that may vibrate against each other
Duct tape
Good quality speaker wire.
Jan 09, 2011 | Focal Access 165 A1 Car Component System
Wiring Apine SPS-600C speakers
hey there,i hope the project turns out great,
1) round up all materials needed such as door components and indash radio,install plug for aftermarket radio,get a radio install kit they are like 10-15 bucks ,and if ur doing a double din radio you will have to cut trim to fit and inside compartment behind radio,but if your doin stock 1 din you will be fine.
2) in order to get to radio in dash you must pull dash bezel off from around gauges and radio and the radio has push down release tabs on both sides of radio ...push these down and pull radio outwards.
3) use new wire plug harness and install radio using install kit so radio sits in it and slides back in with tabs.
4) door panels come off with (3)crews that are 7mm near door handle,bottom of door near speaker,and inside where the switch panel is.must pull up switch panel to get to screw others are visible.
5) take mirror cap off and lift upwards on panel the whole panel will come off make sure to unplug vanity light at bottom door and all switches.remove n set to side door ....remove speaker and unplug then install new speaker cut plug install new crimped wire connector caps and install speaker and do reverse to put door back on and this go's for the otherside as well.
6) if theres more to your system write back with any ?'s ok ill try to help as much as possible.
couldn't find anything about the network?
May 17, 2010 | Alpine SPS-600C Car Component System
Need to remove driver side door panel?
  1. Disconnect the negative battery cable.
  2. If equipped with an accessory switch panel, carefully pry the switch panel up and away from the door panel. Tag and disconnect the switches from the panel.
  3. On 1981-86 models, remove armrest attaching screws.
  4. On 1987-96 models, remove the retainer screws secure the pocket in the molded armrest on the door panel.
  5. If equipped with crank type windows, remove window crank handle with the appropriate clip removal tool.
  6. If equipped with manual remote mirrors, remove the control knob bezel.
  7. Remove inside door handle cover attaching screw and trim plate.
  8. If equipped with door mounted speakers, remove the speaker, and disconnect the speaker wires. For speaker removal and installation steps, refer to .
  9. Remove all external screws securing the door panel. Insert an appropriate prytool between the door panel and door frame to remove the hidden clips securing the panel.
  10. Holding door panel vertical lift straight up to release the upper clip.
  11. Inspect all retaining clips and replace any broken or missing pieces.
To install:
  1. Position the door to the door and carefully press on the retainer clips to engage. If a clip will not engage, inspect the mounting hole behind the panel to make sure the clip is properly aligned. Install any panel-to-door retainer screws.
  2. If equipped with crank windows, attach the washer and crank to the window regulator stud.
  3. On 1981-86 models, attach the armrest to the door using the retainer screws.
  4. On 1987-96 models, insert the armrest pocket and secure in place with retainer screws.
  5. If equipped with door panel mounted speakers, attach the speaker wires to the speaker and secure the assembly to the door panel.
  6. If equipped with remote cable mirrors, attach the control knob to the door panel with the retainer bezel.
  7. If equipped with an ashtray, insert the holder assembly, and secure in place with retainer screws. Install the ashtray to the holder assembly.
  8. Position the door handle trim panel around the door handle assembly, and secure in place with the retainer screw.
  9. If equipped with accessory switch panel, attach the harnesses to the switches, and press the accessory plate into the door panel.
  10. Connect the negative battery cable.
  11. Check and make sure all panel components function correctly.
Apr 03, 2010 | 2002 Ford Explorer Sport Trac
I have a 04 silverado do i need to install my component speakers in series or can i hook up woofer to factory wing and tweeter seperate from factory
With component speakers it is imperative that both the speakers be hooked up to the supplied crossover. Wiring them in series or parallel will not yeild satisfactory results since the woofer requires lower freequency then the tweeter, which plays the high notes.
Now some cheaper speakers do not use crossovers and sound rather poor. What make and model of speaker are installing? Does you truck already have component speakers in it?
Cheers,
Jan 06, 2010 | Alpine SPS-600C Car Component System
VT Commodore 6x9 Speaker install
Hello taz_is_1,
Sure, it's OK as long as the new 6X9's are the same impedance as the door speakers.
Unless there are already wires and cutouts for rear shelf speakers, the installation will be pretty involved. And while I'm not sure of the Holden product, it's sister versions, Chevy Lumina and Omega, does not have such cutouts or wiring.
Wires going into the door interior for window controls, locks, and speakers will all be in a bundle and go from the vehicle frame into the door through a flexible rubber connector with grommets on both sides. You'll need to run your wires from the disconnected door speakers back through the same grommets to avoid pinching and damaging them. After you get them back into the vehicle interior, you can run them under the trim or carpet to the trunk area under the rear shelf. If you have never done such work before, I recommend you get someone who has to help you. You'll need to make an appropriately sized cutout to mount the 6X9's. And depending on the material, you may need some kind of reinforcement and/or spacers. Also, look out for anything underneath the trunk lid that may come into contact with the speakers. There's usually 2 metal rods than span the width of the trunk and run almost directly under the shelf. They will have to clear the speakers in order for the trunk to open and close properly.
It's more work than a simple speaker exchange with a good pair of aftermarket speakers. And the benefit is minimal. A really good set of 5 1/4, 6 1/2, or 6 3/4 Alpines, Bostons, or Infinitys will sound better than a mediocre set of 6X9's any day and you don't have to cut everything up to install them in most door openings.
Hope this helps.
Sep 07, 2009 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
"speaker location"
Yes, You can fit these in the Doors with Modification. Your best Sytem Would be 2 in Front, 2 in Rear, and Sub. If you REALLY Wanna get into it, Go to Crutchfield.com and Purchase the Pioneer 7800 Series Equalizer and 3 Amplifiers. AWESOME SOUND!!!!!!!!! Please Rate My Response! Thanks!
Feb 05, 2009 | Jl Audio 12W3 Car Subwoofer
Iluminite Speaker Instalation 12v DC power
There is 12+ going to the power window switch if you have power windows, you could tap off of that. It's already inside the door, no routing needed. Use continuity test to find ground. Also hook up a seperate switch on the door to turn them on or off.
Oct 17, 2008 | 1998 GMC Jimmy
Blitz BZC5K Car Component System Logo
57 people viewed this question
Top Blitz Car Audio & Video Experts
xxxxxx xxx
Are you a Blitz Car Audio and Video Expert? Answer questions, earn points and help others
