Question about Kenmore Microwave Ovens
How do I opening a lock door on my Kenmore Oven? Model #790.95599102
We lost our owners manual for our kenmore elit smooth top range and forgot how to use the self clean oven.
Posted on May 14, 2010
Shows locked but runs when door is opened
Unplug till fixed ! Replace the 2/3 door switch's inside near where the two locking arms go inside the microwave. get the right ones you can do it.
Apr 12, 2014 | Kenmore 62622 Microwave Oven
Our Kenmore Microwave Hood combo model # 401.88529011 door sticks and is very hard to open off and on
Possible that the door lock is jammed, it can also be due to jamming of the door switch or the plastic lock being stuck on.
You need to remove the front panel , and reset the door assembly.
Jan 25, 2013 | Kenmore Microwave Ovens
Why does my Kenmore model 721.63352300 turn on when door is opened ?
The most likely cause is a defective door switch, there are usually a few to protect critical area's of the microwave oven, if you have a digital meter I can walk you through the testing stage.
Sep 02, 2012 | Kenmore 63252 Microwave Oven
I have a kenmore microhood 63684 turned lites on and can't get them to off,when fan button is pushed fan does not start but when lite button is pushed after fan is energized fan starts real slow and...
What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
  1. Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
  2. Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
  3. Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
  4. Lock your oven door manually if your model does not lock it automatically when you clean.
  5. Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
  6. Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
  7. Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
Nov 26, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
WERE IS MODEL NUMBER ON KEMNORE RANGE?
The model numbers on most Kenmore ranges will be located on a nameplate along the oven door, or lower drawer opening. Some models may have this information on the back of the operator console.
If this question is in reference to a microwave oven, the model number will be located along the oven door opening, or inside the oven cavity along the upper portion on either the left or right hand side.
If you need further assistance, please let me know. I hope this helps you.
Oct 06, 2010 | Kenmore Microwave Ovens
Kenmor microwave 62344 runs but does not cook
Check the door safety interlock system. Remove the cover - test the little switches near the door lock.
These switches fail because we all open the oven door while the oven is operating. Thbis causing arcing and failure. When they fail, the oven doesn't know the door is closed and will not turn on the heat.
Need more help with this ...please ask.
Oct 19, 2009 | Kenmore 62342 Microwave Oven
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Model # 721.80823500
f-5 code on kenmore microwave oven means a problem with the door lock switch. Could be a bent latch or latch assembly that’s not actuating the latch switch correctly or that the latch switch itself is bad. Check the door switch, too.
plse do not forget to accept the solution.
May 02, 2009 | Kenmore 63792 Microwave Oven
Kenmore Microwave Oven door won't shut
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 26, 2008 | Kenmore 63793 Convection / Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
