Question about Murray Feiss - BA1107PB Polished Brass Finish Bathroom Accessories
ELGER ONE PIECE TOILT- PART #495-5515-00
HOW DO I REPLACE Flush valve assembly IN ELGER ONE PIECE TOILET
GOVIND
  • 349 Answers
I need a replacement flapper for a St Thomas Creations enhanced height elongated 1 piece toilet
Did you try to find a replacement flapper by specifying the toilet model, or did you show them what you have? If this is not a power assisted flush toilet, there aren't that much difference between flappers. Worst case you could replace the whole flush valve assembly with a generic type.
Oct 18, 2012 | Seth Thomas St. Thomas Creations 6006.130...
I have to replace the gasket which the flush valve sits on. How do I remove the flush valve. The toilet is Kohler 1 piece model K-3323
The top of the pipe above the flush valve is threaded if you unscrew this you will be able to remove the flush valve and replace the gasket. I am assuming we are talking about the same here is a link that has all the parts:
http://www.plumbingsupply.com/kohlertoiletparts-santarosa.html
Oct 24, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
The water in the bowl keep runing after the tank is full.
fill valve not shutting off water running over overflow tube set or replace fill valve flapper valve leaking replace flapper valve cracked and leaking flush valve assembly replace
Sep 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
One piece toilet needs a new gasket. How do I replace it?
The top of the pipe above the flush valve is threaded. Unscrew it, and you will be able to remove the flush valve and replace the gasket.
May 30, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
What is the procedure for replacing the flush valve assy on a san raphael toilet. it is a one piece tank and bowl assy and must install from the inside of the tank. it appears to possibly rotate into place...
If you purchase the flush valve from Kohler, it comes without instruction. Rotation is the key to removal. First note the exact orientation of the assembly before attempting removal. Unhook the flapper chain and remove the flapper. The old assembly does indeed rotate in either direction for removal. I used a counterclockwise motion. (it was a tough turn, don't break the bottom of the bowl where the valve seat is located.) Then install the new foam gasket on the assembly. The new assembly is replaced in the reverse manner. I removed the new flapper from the flush valve for ease of install. You must put significant downward pressure on the flapper seat while rotation is accomplished. Orient the assembly as was the old one. Replace the flapper, connect the chain and observe the flapper for proper opperation.
Oct 03, 2009 | Kohler K-3384-2-0 San Raphael elongated...
Eljer Canterbury one piece remove flush valve
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Sep 09, 2009 | Eljer Toilet Onepiece Canterbury ...
Flush valve
it is all one piece,replace it with the same model. a plumbing supply house is the only place you will find what you need.
Jul 01, 2009 | Eljer Toilet Onepiece Canterbury ...
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Murray Feiss - BA1107PB Polished Brass Finish Bathroom Accessories Logo
310 people viewed this question
Top Murray Feiss Home Experts
Donni Steen
Tom Chichester
Are you a Murray Feiss Home Expert? Answer questions, earn points and help others
