Question about Sony VAIO VGN-AR630E Notebook
Laptop lid for sony vaio vgn nw20sf - Sony VAIO VGN-AR630E Notebook
    Sergeant:
  • 144 Answers
Check the link to find the price of your laptop model.
http://www.ipc-computer.eu/it-index-n-Sony_VGN_AR_Serie_-cP-7616_38437.html
Kindly rate my help+ Thank you
Posted on May 10, 2010
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I need drivers for dvd
When you say drivers, can you see a program disc in the drive?
If so, simply download VLC media player.
If not, either you have a software problem of a hardware problem. Usually a hardware problem will require replacment of the drive, or a software problem will require the removal of upperfilters and lowerfilters, for which there is a Microsoft Fixit.
Feb 28, 2013 | Sony Vaio VGN-NW20SF/S WXGA HD 15.6" LCD...
Sony Vaio model no. VGN-NW20SF and the touchpad L.H. button has broken.
http://laptoppartstore.weebly.com/replace--remove-sony-vaio-vgn-nw-vgn-nw200-cpu-cooling-fan.html
http://laptoppartstore.weebly.com/replace--remove-sony-vaio-vgn-nw-keyboard.html
http://www.youtube.com/watch?v=8BEcX_0KYIE
You ARE using an ESD wrist strap, and have it's alligator clip attached to a good ground source, correct?
Otherwise you are going to Static shock your laptop, and can use it for a Doorstop.
(Or conversation piece,
"Hey what's that Stewart?" "Oh that was an attempt to repair an old VAIO I had." )
Average price is around $3 to $6. One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving tray (Unpainted), on the TABLE you are working on, and connect to it.
Or a large metal knickknack (Unpainted)
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
(You can use a clean egg carton if you need to)
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
(Especially since there is no free Service Manual)
Let's look at some of the casing parts, to familiarize you,
http://www.ebay.co.uk/itm/NEW-SONY-VGN-FW-series-PALMREST-complete-p-n-X23181224-/300437553756?pt=UK_Computing_Other_Computing_Networking&hash=item45f379425c
Get the Sony part number off of the Touchpad, to look up a replacement.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 26, 2012 | Sony Computers & Internet
No disc for my sony VGN-NW20SF
download divers directly from sony
Jun 07, 2012 | Sony Computers & Internet
Its been 2 years since i bought my sony laptop VGN-NW20SF it was properly working before...now my built in camera not working VGN-NW20SF??
Try installing the latest WEBcam driver.
You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
May 21, 2011 | Sony Computers & Internet
Sony vgn-ar250g the light is lid but the operation system won't s
It is because your memory is faulty so try to replace the RAM ..
Nov 05, 2009 | Sony VAIO VGN-AR250G PC Notebook
Can I run a Sony Vaio VGN-FS980 laptop closed?
You should be able to go into power management utility whether it be sony or Windows and change the "when lid is closed" option from hibernate/shutdown to "do nothing"
on XP
CP>Power Options>Power Schemes
Jun 10, 2009 | Sony VAIO VGN-FS980 Notebook
Sony VAIO VGN-AR630E Notebook Logo
127 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
