I tried to adjust my setting on my RCA 27 inch tv without the remote and I pressed FPA On and the tv went off and wont turn back on. How do I get it to turn on? Please help!!!!
I found my remote. the only way to get the child locks off.
Posted on Mar 30, 2008
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
I have and rca tru flat tv and my FPA lock is on... i have a brighthouse remote that im using on it but i need to know how to turn it off
Hello
Without its original remote control, opening the FPA lock of RCA will be difficult. Just try to get one new remote for this set or jut borrow it from any of your friends or relatives who own the same model set, just to open its FPA lock. After opening lock, you can use your brighthouse remote. You can open the lock with one amoung the following procedure.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Jun 27, 2011 | RCA TruFlat 27F520T 27" TV
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Apr 30, 2011 | RCA TruFlat 27F520T 27" TV
I hit the FPA and now i am screwed how do i fix this it I cant get into my tv
Child Lock allows you to lock the buttons on the front of the TV.
Press MENU to see the main menu.
Press CH+ or CH- to highlight
Preferences.
Press OK to enter the Preferences
submenu.
Press CH+ or CH- to highlight FPA
(Front Panel) Lock.
Press VOL+ or VOL- to turn on or off
FPA Lock. Choose On to disable all the
buttons on the front of the TV. FPA Lock
On will appear on the TV screen each
time you press buttons on the front of
the TV. You can still operate the TV with
the remote control. You can still use the
POWER button on the front of the TV, but
only to turn off the TV (not on). Set FPA
Lock to Off to cancel this feature so you
can use the buttons on the front of the TV
again.
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
I hope this helps and good luck!
Nov 15, 2009 | RCA TruFlat 27F520T 27" TV
It wont turn on its stuck on stand by any suggestions? when we do get the tv turned on we cant knock it off or it takes hours of fiddling with the remote standby button to get it back on the tv is a...
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Let me know if you need more help or info.
Nov 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
Fpa lock on my rca tru flat tv
here is my solution. somebody either needs to give me a solution without a remote or fuckin mail me a remote. and if i ever run into these RCA dipshits, ima beat some ***** *** for puttin the damn lock on there in the first place.
signed,
Jay and Silent Bob
Dec 26, 2008 | RCA TruFlat 27F520T 27" TV
Rca truflat locked
Hey this same thing happened to me not too long ago and you just have to buy a Universal remote and program it (it should come with the codes to program it to your TV) I think the code is 704 or 702 for RCA... Anywho after that then you can turn your tv back on wit the remote and push menu and Preferences and then FPA off. Its just a parental control block so your kids cant touch the tv buttons and mess with your settings.
Sep 25, 2008 | RCA TruFlat 27F520T 27" TV
RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Oct 02, 2007 | RCA 27F530T 27" TV
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
