Question about Maytag PDB4600 Built-in Dishwasher
Too much sink water causes flooding from dishwasher.
Maytag Jetclean Quiet Pack. Do not know model #, but it is about 10 - 15 years old. Running water from kitchen sink for an extended period of time causes water to collect in basin of dishwasher and eventually runs out onto the floor. I don't know where to look for the leak, whether or not it is caused by a clog, or where the overflow is coming from, but it does flow under the cabinet onto the floor on the other side of the kitchen wall.
Today is Sunday, May 9th, but this also happened on this past Easter Sunday, too. At that time, we drained the basin, mopped the floor and tried to clean what looked like drains on the left and right basin of the dishwasher, where the door meets the basin. I let it sit overnight with vinegar and ran it the following morning and it's been fine until today. Any ideas? Thank you. Joseph Vomero
  • 2,049 Answers
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Posted on Mar 14, 2017
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
  • 142 Answers
SOURCE: Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Posted on Jan 27, 2009
whytfang
  • 170 Answers
SOURCE: water leaking onto the floor
1. If the water is going onto the floor during the drain cycle there is either a hole in the hose or it is completely loose from the DW or a hole in the drain assembly under the sink but if that were the case you would have water under the sink also.
2. If it during the wash or rinse cycle then the seals are not sealing (door is not closed all the way or seals are bad) or the float at the right front of the DW is stuck allowing the DW to overfill with water.(you need to open the door and pull the float up and out as you do so push it up and down and listen for a clicking sound.(which indicates it is making contact with the fill solenoid)..if you here the clicking and the float is full of gunk (old soap and such) clean it out and replace it and run it through a cycle and monitor the DW to see if the fill cycle shuts off before the water reaches the overflow point.
3. the only other option is a possible rust through on the DW and or the drain and motor mount in the center of the DW where the food particles and water are drained...is loose and leaking or rusted through...(how old is the DW).
4. Also check to see there are no large particles around the door seal to prevent complete closure and sealing of the door seal. As well as the door latching properly (when closed can the door be moved or pulled open)?
I hope this helps and let me know if not Please relay model number, age and other specifics you feel are pertinent...thank you and please rate me if this helped...thanks again ...the Fang
Posted on Mar 26, 2009
  • 5 Answers
SOURCE: Dishwasher does not drain
The drain runs from the dishwasher into either the side of your garbage disposal, or directly into your sink drain. If it is running to your disposal, pull the hose and make sure that the plug in the disposal (where the hose connects) is knocked out. Some have been known to install them without removing the plug. Either way, pull the hose loose and you can use a compressor to blow through it. If the air comes back through the dishwasher, then you are probably blocked in the main drain.
Posted on Jun 22, 2009
heatman101
  • 43501 Answers
SOURCE: maytag jetqueen door leak
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dfg
Posted on Sep 29, 2010
DW running but no water
check flood switch float is on(the float under the bottom rack)...also the switch under that...also you ca use a 110 volt test cord to test the inlet valve
Aug 25, 2009 | Maytag MDB9600A Jetclean II Built-in...
Vibrating dishwasher pipes
a plumber needs to install a anti knock pipe at the valve under the sink ....this should stop the vibes ...should only cost about 50 -75 bucks ...depending on the per hour rate of the plumber
Jul 26, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Quiet Series 200: The water is not draining out.
6 to 7 years is about right without put out major repair costs. Unfortunately salesmanship is the biggest racket going. I'd scrap it or sell it for parts. Sorry
Jun 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishes are`t clean ,arms dont spin during wash cycle
what is the model # how mutch water is in the basin?
Jun 28, 2009 | Dishwashers
Water will not drain out of dishwasher
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher fills with water when running faucet
The drain hose from the dishwasher should exit the dishwasher, then head up to the nderside of the counter top, before heading back down to connect to the disposal drain connection.
If the drain hose doesn't do this, the dishwasher is improperly installed, and clean dishes risk being contaminated, which can cause people to become ill.
Jan 25, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Hi olabrk,
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Plumber fixed the sink, now dishwasher is broken
sounds like the water is off, too coincedantal to brek after the plumber is there, the hot water under the sink is where the water supply to d/w is. obviously youre hot water at sink is working, there shloud be a sperate on/off valve for the d/w somewhere nearby
Mar 07, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Mdb 6600aww
i need your serial num its important
Oct 19, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag PDB4600 Built-in Dishwasher Logo
76 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
