Question about GE (PSS26MSRSS) Side by Side Refrigerator
Saw that the icemaker,looked like leaking water under it...right under the ice bucket ..down into the freezer..its making ice...possible control board or water valve problem...
  • 3 more comments
  • Michael Dorris May 10, 2010
    hi how are doing...im a tec that fixs appliances an hvac...the problem im having is the ice maker is dripping water,thogh it is making ice,right under the ice bucket...down into fridge...i think it might have a leaking water valve...ge side by side...have you seen this...michael
    im a tec ,have a problem with a side by side refrigerator...ice maker is making ,ice..but is leaking into the freezer,right under the ice bucket assembly..like a bat..size..suspect water valve or control board...please give input...ge profile...artica..digital dispencer readout..
  • Michael Dorris May 11, 2010
    hi how are you...this a im6 ice maker...digital board...im leaning toward the water valve..i replaced the ice maker for the second time to be sure that it was not the icemaker....two being bad is uncommon....what do you think...have you heard of the motherboard causing a issue with this on a ge artica,prfile....
    i got one more question,if i replaced the ice maker a second timer..is there a problem i dont know about with im 6 ice makers...a splahing problem or leaking....or maybe a weak water inlet valve...i think the valve could be the problem....
  • Michael Dorris May 14, 2010
    a very kind ,helpful person...tthanks...
  • 821 Answers
Hello,it is a water valve problem,all you need to do is just to change the water valve and also check the water level should always be checked if water valve is replaced,
wish you good luck,
TAKE CARE.
Posted on May 12, 2010
    thank you for your kindness...you sound like a kind person....take care sure....
    President:
  • 2,923 Answers
Its hard to say where that water is coming from, either the fill tube or the ice maker itself is leaking.
You can manually cycle your ice maker by taking the front cover off of it and turning the ice maker gear in the direction on the arrow stamped on the metal plate just above it.
Check the link and it will give you an idea:
http://www.applianceaid.com/pictools/IM3large.jpg
If same problem occur, then it could be the inlet water valve.
Thank you and good luck!
Posted on May 10, 2010
  • 1 more comment
  • Melvin Ramos
    Melvin Ramos May 11, 2010
    Nope, if the mother board is causing the problem, the common symptoms are:
    Ice maker won't produce ice, strange noise and won't dispense ice.
    But for your case, it has something to do with the valve that's connected to it.
    Thank you!
  • Melvin Ramos
    There is no known issues with im6 ice maker. Replacing the ice maker is not a good idea. It will only cost you.
    The best suggestion is, to have a pro to take a look at it. It will save money and for sure, he can fix it.
    Contact a pro first before deciding to replace it.
    Thank you!
  • Michael Dorris May 12, 2010
    thanks for your help...but im a tec....i did not need a sacasic remarks...i own a business...i have not run into problem with a ge fridge before ,like this....just like you ,you dont know every ,make an model ,problems...thats why we ask others for input....or tec help...a question not asked is a dumb question..
  • 2,069 Answers
There is a very good video here that can get you started and have your problem rectified.
Can this ice maker be set to make more ice? And faster?
Icemakers cycle cubes from the air temperature inside the freezer so you can't do much to increase speed except adjust the freezer control colder. As to the bucket not filling, most icemakers have a feeler arm or plastic paddle that is suppose to sense the ice level in the bucket. Make sure the feeler arm or paddle at the bottom is free and no sticking or hitting anything. It needs to move freely ask the icemaker dumps the cubes. If your refrigerator is less that a year old it should be under warranty and a free repair to you.
Apr 30, 2015 | Samsung RF4267HARS Stainless Steel French...
Leaking ice maker inside freezer
You didn't say -- was this freezer working correctly for some time before this problem?
It's not unusual for an ice buildup in the icemaker itself to divert water to places it's not supposed to be. The only fix for that is to turn of the freezer (you may have to turn of the refrigerator, too), and completely defrost the freezer. Leave the refrigerator door closed and it will stay reasonably cold. It may take a couple of hours to fully defrost - put some towels in the bottom, as it sounds like you'll have some ice buildup to deal with. You can speed that up a lot with a hair dryer. Just turn it on high, and direct it at the ice buildup, and then concentrate on the icemaker and the area around it.
If you can, inspect the icemaker area and make sure the fill tube is directed into the ice tray, and hasn't gotten bumped or moved so it's pouring water elsewhere.
Once the freezer is completely thawed out and all the water mopped up, start it up again and cross your fingers.
May 05, 2017 | LG LSC27914 Side by Side Refrigerator
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Ice maker leaks or runs over Causing big chunks of ice in the drawer
It's very possible that the water inlet valve isn't cutting off completely. I had that to happen on mine.
Mar 17, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Ice maker leaking down in freezer along left side. I shut off the water and turned the icemaker to stop. How do I fix the leak?
Look for any tilt in the icemaker towards left, if so loosen both the screws, balance the icemaker.Then tighten the left hand screw first followed by right hand side
p.s the screws will be holding the ice maker with back wall, once you remove the ice bucket it will be visible
Aug 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The icemaker makes ice, but it won't dispense.
rmielsen and PhyllisForbe,  Your refrigerator has an auger motor that causes the ice to be dispensed when you press the ice selector on the front of the refrigerator.  You could have several possible problems that will gives you the same result.  The auger motor could be at fault. The ICE selector part of the  control panel of the front of the refrig could be at fault.  To isolate to auger or control... do the following.  Remove the ice bucket or auger assembly from the freezer. Reach into the freezer compartment where the auger assembly normally would be.  You should be able to see a "horse shoe shaped metal drive assembly" that would mesh with the auger assembly (ice bucket) to turn the cork screw shaped auger. Try and turn the auger drive assembly in rear of freezer to determine if motor armature is free.  The is somewhat difficult to do because the auger motor is high torque, slow rpm motor, but it should turn if it is good. Sometimes the auger motor will become stuck due to a water leak, inactivity, high humidity during a defrost cycle, etc.  The more possible suspect is the ICE selector assembly on the front of the refrigerator.  If any function on the refrig fountain dispenser control panel goes bad...then the ice/water control assembly will need to be replaced.  Hopes this helps you!  HandyHenry
Jan 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Nov 17, 2007 | KitchenAid KSCS25IN Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
51 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
