Question about KitchenAid KSRS25IL Side by Side Refrigerator
Not cooling fan is working but theres no cool air
    Scholar:
  • 110 Answers
BAD CURRENT RELAY VERY COMMON AND EASY FIX FOR A TECH
Posted on May 30, 2008
Gets hot and runs very rough when idling as if its about to stall, cools down as I drive.
Check that the cooling fan is working of if you have a viscous fan hub check that it is operational. Electric fans should be working at around 80 degrees C and just because the viscous fan is spinning doesn't mean that it is driving to pass enough air through the radiator. The statement "it cools down when I drive" is a clear indicator that there is no air passing through the radiator at idle and by driving- the air is being forced through the radiator so it is cooling down
Sep 06, 2013 | 1995 Toyota Camry
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
I have a 2002 Dodge Ram Quad Cab 4x4. The a/c runs great as long as the truck is moving, but as soon as you come to a stop it starts blowing warm air. Please help.
Generally if the a/c works fine at highway speeds but kicks out or slowly begins to blow warmer and warmer air as the vehicle is driven at slow speeds or is stopped the a/c condensor cooling fan is usually at fault. At highway speeds there is enough air being forced through the radiator, condenser, and oil coolers to keep everything working and cool but when the vehicle is moving slowly or is parked the electric and mechanical cooling fans have to be working to pull enough air through to keep things working. If the cooling fan isn't working or can't pull enough air through the a/c condensor the system will kick out once the internal pressure reaches a certain point. Once the vehicle is moving again the system can get rid of the heat that it has gathered from the passenger cabin, the pressure drops back to normal and the system cools again. I would start by looking for a blown cooling fan fuse in the fuse panel under the hood. Usually they are 25 amps or larger and run only the cooling fan.
Jun 14, 2010 | 2004 Dodge Ram 1500
Cooling fan on radiator do not work sending unit on block checks ok with oms meter relay in fuse box ok now what
Change the thermostat and bleed the ir from the cooling system,then ,if the cooling fans do not come on,check the relay module under the cooling fans on drivers side,they are bad to go out,but if there is air in the cooling system,the cooling fans will not come on.
May 31, 2010 | 1998 Dodge Caravan
I have 2003 grand cherokee with 140000 miles that overheats at idle. as soon as i start moving again, the temp goes back to normal.
You have two fan's on your truck, 1 is a fan clutch runs with the drive belt, 2 elec fan motor, with test light and engine running at normal temp, just a little bit above 1/2 way on your temp gauge check voltage at elec. cooling fan harness if you have voltage at one of the two wire's and fan don't turn on, bad cooling fan motor, on the fan clutch after you check voltage at elec. fan motor turn engine off, with your hand spin drive belt fan if it spin's freely bad fan clutch, replace it.Also check cooling level.Hope this was very helpful
Jan 21, 2010 | 2006 Jeep Commander
My fan isn't working
well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Jul 14, 2009 | Heating & Cooling
Cooling fan not working
sensor may be bad. . any other symptoms that you think caused the cooling fan to fail?
May 27, 2009 | 1996 Nissan Maxima
My Blueway air con is not cooling , fan works but is not cooling
More than likely the capacitor is bad internally
Jan 21, 2009 | Heating & Cooling
Sunpentown SF-609 Evaporative Air Cooler - no cool air
Sometimes there is a separate switch to turn on the water pump. No water=no cooling. Check to make sure the cooling pads are wet! If they are completely wet and the fan is blowing it should cool.
Jul 06, 2008 | Sunpentown SF-609 Air Cooler Fan
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
KitchenAid KSRS25IL Side by Side Refrigerator Logo
60 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
