Question about 3M 5/8 x 8 - Low-Melt Adhesive Clear
Good morning i have used an adhesive to glue a rubber patch onto my rubber dinghy- the patch up was unsuccessful, so i now have to remove the patch, get rid of the glue and try again with another patch. what is the best substance to use to remove glue- without having to sand the glue off?
    Brigadier General:
  • 4,090 Answers
PETROL is the usual solvent for rubber glues
please rate my help++++Thanks for using FIXYA
Posted on May 10, 2010
Testimonial: "thank you so much for your positive response, petrol did not work- a bit of sanding and then thinners worked"
Tip
Save even more money! I did this repair for under $20. Instead of replacing the...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on May 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Glue for shoe repairs.
There is a glue for shoe repairs -
Technicqll Transparent Shoe Glue Rubber Nylon Leather Felt Strong Adhesive R341
Apr 11, 2017 | Clothing Accessories
Weather stripping is coming off the doors on dodge caravan What glue to use?
There is a glue from 3M at AutoZone for about 10.00 dollars. This is strong stuff! Part number 08001.
Jan 25, 2017 | Dodge Cars & Trucks
When replacing a bad gasket do you glue it on or what is the best way to adhese it to the preexisting rubber... v2240 food saver
Hi jab500...
I would recommend a good adhesive such as 3m Weatherstrip Cement or Contact Cement to glue the gasket in place. Use a small amount of cement, in case you want to replace the seal in later times.
By glueing the gasket in place with cement it will not come loose during use.
Please take time to rate me
Sep 04, 2011 | Tilia FoodSaver V2240
I have kit, but no instructions on how to repair a bike tube. help please.I have bike tube repair kit with patches, glue and metal things
The metal thingy is used to roughen up the tube, where the patch will go, so the glue will stick. The glue may have instructions on it, but place glue onto the patch and the tube and let it dry for a few minutes, then place patch over hole.
when refitting the tube, sprinkle some powder on it around the patch and inside the tyre, make sure you have removed whatever caused the initial puncture. Try to refit the tyre without using any levers, so you dont pinch the tube again
May 10, 2010 | Cycling
Difficulty in replacing v6 valve cover gaskets
at auto store they sell gasket adhesive or use a little silicon and clean cover til oiless ( use break cleaner) and glue gaskets in place and let dry and then install
Jul 08, 2009 | 2002 Toyota Tacoma
Hole in subwoofer
Hello colinomalley,
You can repair the hole using a flexible permanent adhesive. If all of the cone is still there, I wouldn't use a patch. I'd just put the jagged edges back together. If part of the cone is actually missing, you will need to patch it. Thin fiberglass cloth works pretty well. Use painters tape that will remove easily and cover the hole from the rear of the speaker. Cut the fiberglass cloth about 1/4" larger than the hole and attach it using a silicone based flexible adhesive. Allow it 24 hours to set up completely and then remove the tape from the rear.
A product called "shoe goo" works very well for speaker repairs. It's strong, flexible, and permanent.
Hope this helps.
May 26, 2009 | MTX Road Thunder RT-1240 Car Subwoofer
How to repair a artic rocket
The Arctic Rocket is made of PVC Vinyl. Nothing else will stick. Make sure you slightly scuff the area before you try to patch it.
Feb 01, 2009 | Artic Silver Alumina Thermal Compound Tube...
Bounce House
My best thought is to use an adhesive (rubber cement will do the trick) to apply the patch then heat it with a hair dryer.
Dec 14, 2008 | Toys
3M 5/8 x 8 -  Low-Melt Adhesive Clear Logo
141 people viewed this question
Top 3M Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a 3M Craft and Hobby Expert? Answer questions, earn points and help others
