Question about T-Mobile Sidekick
SIDE KICK GOT WET AWHILE BACK .IT TURNS ON BUT NOTHIN ON THE SCREEN
Hp Presario 2000 will not get to windows sign in
Do you see an error message on the screen or, does it blue screen with an error message? When you boot up press F6 just as the PC drops out of BIOS mode. Select "Last Known Good Configuration". If that doesn't fix it, look up the error code on the blue screen with Google. Most blue screens are fixable. Some require a complete rebuild of your hard drive.
Aug 25, 2013 | Fujitsu LifeBook S6510 Notebook
I have installed a brand new 4 hp pump and a brand new Balboa heat and control package. I have wet vacuumed all the jets and removed filter. Pump is still weak and kicks off after awhile. How do I...
most of the jets in a Hot Tub are adjustable. the face of each jet can turn on/off. Make sure they are all open or you will not have good water flow and cause too much back pressure on the pump and cause it to fail.
check the jet faces when you turn the pump on.
also a dirty filter will cause low water flow so check that too. take it out and see what pressure you get through the jets.
Jan 29, 2011 | Home
Turned ON ..nothin BLUE SCREEN ONLYy
did the phone get wet or dropped? I would fully charge it and hen take out battery and put it back in, If it is new, take it back to the store and get it replaced
Aug 26, 2009 | Motorola Cell Phones
Razr V3 water damage
Sounds dire. If you look inside the back of the phone, there should be a small spot that turns from white to pink when the phone gets wet. If that spot is bright pink, most repairers won't even bother trying to fix it. Best off buying another phone!
Apr 07, 2009 | Motorola Mobility RAZR V3
Kenmore side by side runs then stops
When you say runs awhile, how long? What is shutting off all power or just compressor?
Nov 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Mar 30, 2008 | Frigidaire FRS26ZSG
T-Mobile Sidekick Logo
93 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
