Question about Epson Stylus CX6600 All-In-One InkJet Printer
Printer won't print and dose not show errors. When I tell the printer to print, it goes threw the printing stage but know ink comes out
    Sergeant:
  • 144 Answers
Check the cartridge ink or replace with a new cartridge to solve it.
Kindly rate my help+ Thank you
Posted on May 10, 2010
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
Canon mg5220 printer won't print black
Try this: take a small, sharp knife and make sure the air slit on the top of the cartridge goes all the way through the plastic.
You know that little tab you have pull off the top of the cartridge before inserting in the print head? There is a tiny slit under the tab to let air in, which is necessary to let the ink flow out. The slit is made very small so ink won't leak inadvertently out the top. Sometimes the slit doesn't go all the way through the plastic. When that happens, the ink can't flow.
I blew through that slit on a defective cartridge and no ink came out. I used a pen knife to open the slit (it doesn't take much) and then blew again. This time ink spewed out the bottom. My print test showed the black ink coming through. It was a bit spotty so I cleaned the print head and now the black ink comes out just like its supposed to.
Mar 13, 2012 | Canon Pixma MG5220 InkJet Printer
HP D135 PRINT error
I am sorry the print head goes out on the B And W on these things quite frequently. however you can go to www.hp.com amd go threw thier secdualed way of testing the print head but am sure you will find it defective. I had one and it was a problem. B e aware they have a new head that replaces the old head that lasts much longer.
Oct 05, 2009 | HP OfficeJet D135 All-In-One InkJet...
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Dell 922 won't print
Myprinter won"t print it says it is the Dell photo aio printer 922 is not working . how can i get it to work. thank you
Jan 26, 2009 | Dell 922 All-In-One InkJet Printer
Lexmark Z715 will not print but computer says it is printing
The Z715 needs a #50 black ink cartridge and a working color cartridge to print. To check if there ios ink coming out of your black or color cartridge touch the bottom of it to a paper towel and if you see a solid black blob or 3 blobs of Yellow, blue and red for the color then your problem is else where. If U are printing stuff from the internet sometimes the printer will try to use the color cartridge to print this so even though the black is working it comes out blank if the color is dry
Jan 16, 2018 | Lexmark X4650 InkJet Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Error code
and even if you did get rid of error 51 that you have created, you will find that you still cant print in black, original problem is the print head is stuffed probally from dodgy non gen ink running threw it and the fix is to replace head. I don't know who is telling all you brother mfc owners to clean your print head but your paddling up the wrong creek, these heads are electronic deivices that dont take kindly to cleaning, they are not the same as other brands. Re error 51 goto different machine same engine post
http://www.fixya.com/support/t277162-brother_420
Dec 04, 2007 | Brother MFC-5440CN All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
161 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
