One side of a brand new 7'' does not work, the other side plays fine... it slows down, then returns to normal, slows down, then normal about once every second WHAT IS HAPPENING?
  • Audio Player... Master
  • 5,342 Answers
The fact that the turntable can play the other side of this 7" single (and I would guess others) shows that it is working fine. So I'm afraid the recording on that side is faulty. Take it back to the shop and see if they will swap it or give you your money back.
Posted on May 11, 2010
New Husqvarna 125B blower runs fine then stalls
Is the gas fresh or old that you used. Since this brand new, it's under warranty. If you've had it for a few days, return to the store from which purchased it. It should run right out of the box without having to work on it.
May 16, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
When I play audio or video files they play fine and then suddenly start dragging for 15 sec. -1 min. then return to normal , I have also noticed when I play pinball the ball motion is jerky and fl
The most likely problem is that you are either, buffering from an internet feed (slow internet) or you are overloading the processor. The Pinball would indicate that your processor is too slow. Buy a new graphics card or more RAM. Also run CCleaner to get rid of any rubbish that is slowing down the computer.
Apr 18, 2013 | Dell Dimension 3000 PC Desktop
Sewing slows after use
The manual: http://www.singerco.com/uploads/download/446_5040_5050.pdf
Jan 08, 2012 | Singer 5050 Mechanical Sewing Machine
Turntable stops before the end of a 45. Works fine for Albums. I found 1 solution but that says to take the player apart.
Just had this occur to me and after a couple seconds figured it out. Tonearm returns once it hits a certain height on the tonearm guide (the bit that goes up and down when you raise or lower the tonearm cue lever.) If you manually hold down the guide, the tonearm will continue to play the 7" until the end. You don't have to push down hard, just a nice gentle [pressure while the record plays should do it. It solved the problem for me.
Apr 23, 2011 | Crosley 0187SST Turntable
Will play normal dvds but says any blu ray dvd is incompatible,brand new plaer only been used about 6 times to play movies .It worked fine last time it was used.
Return it to the seller. This unit is clearly faulty and does not perform as per manufacturers description.
You are within your rights to have this REPLACED rather than repaired.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Sharp AQUOS Blu-ray Disc Player
Slowing down suddenly when gaming
Hi rajiv2612.
Suggest you check for any software update's from GeForce for you're 8600 GT. Also check for any software patches for the game (s). (Include windows update service as well).
The normal stuff like running windows system defrag & disk cleanup utilities should be run once a month for gamers.
Lastly, if you feel heat may be an issue. Open the PC case & leave opened while playing the game that seems to slow down the most. If the game does not slow down (After checking & updating all of the above), than maybe you need to add a 3" fan to the case, so fresh air blows directly onto the 8600 GT.
Good Luck!
Mike
Jul 14, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
I am in NZ and have philips 616K dvd player. Have some dvd's origin UK that wont play on my dvd. Comes up wrong region. My daughter also in NZ has played these dvds in NZ but not sure what brand dvd she...
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', 'l' in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
Jun 28, 2008 | Televison & Video
Menu Problem
Did you try calling Canon tech support or returning to retailer if the camera is really not functioning properly this soon after purchase, I'd try returning it once all troubleshooting issues have not resolved the issue.
Hope this helps!
Feb 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Operating Speed of N73 .
n73 is slowing down mainly because of the ram leakage. To see the amount of free ram install best taskman.search with google for the key.
Feb 16, 2008 | Nokia N73 Cellular Phone
Plays but pauses every 30 or so sec
Had this problem that degraded into a frozen player within 1 DVD with the error H02. See: http://www.fixya.com/support/t115888-dvd_not_playing_message_say_h02
Mar 07, 2007 | Panasonic DVD-RV31 DVD Player
47 people viewed this question
 Grubhead
Grubhead
