My Cabrio washer leaves oil stains on my clothes. Could I fix this problem myself?
SOURCE: grease spots and stains
Yes you can. Remember a front loader has no gearbox so no oil is coming from there? fabric conditioner, washing powder,and oils from our bodys can build up on the tub walls. All it needs is a good flush out. You can use dishwashing powder. Run it through with no clothes in you washing machine on a hot wash or a wash and hold a couple of times to flush it out. NZL
SOURCE: leaves
There's a chance that clothes are getting under your agitator and rubbing on the shaft. It's dirty there. Feel under the agitator. If you can get fingers under it past one knuckle(guy's fingers), clothes just might get there too. The only fix is probably a new agitator. Compare the old one with a new one, see if the new one is lower. Agitators come off easy, a bolt is under the Downy dispenser, pull the plastic cover up. Check your agitator dogs while you're there. There's a site here where you can get new ones.
SOURCE: WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
SOURCE: Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
