Question about Boss AUDIO SYSTEMS D13002 Car Audio Amplifier
Blowing fuses I recently upgraded my subwoofers to kicker CVR's and when i pulged up my amp, the fuse keeps blowing out on it, can any one help me with this problem?
  • 733 Answers
It's drawing too much current. make sure you have a nice solid ground to your car chasis( i use seat bolt or something like that) and that your wire is the right gauge. If it's still popping your fuse make sure you are wiring the subs as specified by the manufacturer.
Posted on May 10, 2010
Can I wire a 2ohm Kicker CVR with a 4ohm Kicker CVR to a monoblock amp 1 channel
yes. google, impedance calculator and it will help you out on how to wire it
Apr 12, 2015 | Kicker Car Audio & Video
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
What's the best way to wire a 12 inch kicker CVR
Ok, first you need to have at least ten gauge wire cause the amp needs agility of juice. Next you want to find a good ground to frame of the car (if its wrong you'll hear road noise through speaker.) Next look on the fire wall and find the terminal that has other wire coming to it (one from positive to the amplifier on battery the rest out top other you want to put an inline fuse to amp.and have ground write other side of the cart than the power. run write to amp then to your speaker I believe I made it is simple for you as possible good luck
Dec 07, 2011 | Kicker Car Audio & Video
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
I just bought a cvr kicker 10' sub, hooked it up in my car replaceing a polk audio sub. The kicker keeps blowing my fuse. i have checked the wireing. i have an 800watt sony xplode amp. Please help
i am assuming that you bought this sub used? their could be a problem with your voice coil. the voice coil moves the cone of the speaker in and out. the problem with the voice coil is that it has become lose and is doping the impedance of the sub. A lose voice coil can be cause by over powering the sub. this problem is not fix able.
Aug 01, 2011 | Kicker 01C8VR4 Car Subwoofer
What amp should i use for 2 15-inch cvr
goto www.kicker.com you can use there recommended amp to subwoofer guide to get you answer. however i would say use the zx1500.1 amp since it has a 1500 watt rating which about the same as you subwoofers.
Jan 29, 2011 | Kicker Car Audio & Video
Hook up
how do you wire up a kicker cvr 12
Jun 14, 2008 | Kicker CVR12 Car Subwoofer
Subwoofers not bumpin, amp is still on
Check to make sure there is a good input to the amp. Next check each sub to another source to make sure they are good. Look for any reset on the amp.
Apr 26, 2008 | Kicker CVR12 Car Subwoofer
2 12'' cvr kickers
ya u allreadyfound ound out the problem u have factory amps there u go after market
Feb 27, 2008 | Kicker CVR12 Car Subwoofer
Boss AUDIO SYSTEMS D13002 Car Audio Amplifier Logo
124 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
