Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
Sony kp-65w5510 rear projection tv power button malfuction
Sony kp-65w5510 rear projection tv when i press the power button it tries to turn on but it just clicks about four times then shuts off. the screen does not turn on
    President:
  • 1,619 Answers
Replace bulb and clean cooling fans of dust is the first thing to do. if that doesnt work might start checking capacitors on the power supply.
Posted on May 10, 2010
Hi? My Sony Projection T.V model KP-FX432M91 is taking time to power on and once it has powered on it work fine.what might be the problem?
Power button may need to be replaced. Try turning on via remote.
Some TVs need to warm up before coming on. Hitting the power button several times may in all actuality be Turing it off and on.
Sep 20, 2016 | Sony Kp-Fx432M91 43" Projection Wega...
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
My sony KP-46WT510 has double images and the edges are red and green
Try pressing the Flash Focus button on the TV to adjust the convergence of the TV.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 22, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a KP-57WV7000 that will not turn on. I got
try to turn the tv on using the sony remote and this sequence of buttons push display 5 volume up then power if the tv comes on change ic8002 on the power supply if it doesnt try replacing anyway this is a common issue with sony tv's
Jan 24, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
TV will not come on
i have a sony rear projection TV, model number kp43t70 screen went black and there was still volume but no pic so I turned it off and now won't turn back on
Aug 23, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a sony projection tv model #KP-51WS520. The tv won't turn
On the remote, hold down the reset button, press power button on the tv set, release the reset button on remote control. This is a factory reset> If TV does not recover from this call 1-800 222-sony for repair options. Good luck
Jul 07, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
Dec 05, 2008 | Sony KP-57WS520 57" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Oct 03, 2008 | Sony KP-61HS10 61" Rear Projection...
Television wont power on
Is the led blinking? If so please let me know how many blinks its making before pausing for a second.
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
My tv is broken
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Try the suggestions on this post from the Troubleshooting page: http://www.fixya.com/problems-solutions/t101379,p228476/Sony-KP-48S75-48-in-Rear-Projection-Television.aspx
Jun 18, 2006 | Sony KP-48S75 48" Rear Projection...
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
239 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
