Question about Car Audio & Video
I have a P12DVC 12'' Inch Planet Audio Subwoofer and would like to read the online user manual. I need to know if series or parallel wiring is better, (kenwood 600watt amp) 2 channel, also how many cubic feet is best when building a sub box for this subwoofer. thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
I had found out you can down load all most any maunal for car audio from retrevo.com and type in your model number hope this was helpful
Posted on May 11, 2010
I have 2 2 ohm dvc alpine type r 12 inch subs. Each voice coil on both subs reads 2.5 on ohm meter. I need wireing diagram to hook up to a boss 2500 class a/b amp at 2 ohm
To have 2x 2 ohm subs wired up, they either need to be wired in series or in parallel. In series, they will total as a 4 ohm load to the amp (or 5 ohms if 2.5 each) and in parallel, they will be 1 ohm (may be closer 1.25 ohms I think).
If this is a mono block (single channel) amp, I can't see that you will be able to wire them for a 2 ohm loan. You may have to wire them in series to be a 4/5 ohm total as the amp probably won't be 1/1.25 ohm stable.
Apr 27, 2017 | Alpine Car Audio & Video
Don't know how to wire a kicker solo-baric L7 2 ohm dual voice coil 12 inch sub
Wire in series for 4R. +ve of coil to amp +ve. -ve of that coil to +ve of second coil and the -ve of the second coil goes to -ve of amp.
Aug 10, 2017 | Car Audio & Video
Can my la590 American legacy 2 series 800 watt handle Boss CX122 Chaos Exxtreme 12-Inch Subwoofer 4-Ohm Voice Coils??
It is only stable to 4 ohm mono(which is 400 watts RMS or a bit less not the max rating of 800 watts which is a PMPO rating).
Your Sub would have to be wired in series(8 ohm final load, if you wire it in parallel 2 ohm-you will fry that amp).
Jan 07, 2014 | Car Audio & Video
Need help.. I have two 12 inch dual voice coil kicker comp vrs.. they are 4 ohm subs..how do i wire them to get a final ohm load between 1.5 to 4ohms in a dual enclosed box...Im hooking them up to a jl 500...
To do this they MUST be wired in parallel, IE: Plus to Plus, Negative to Negative. 2 4 OHMS in parallel is about 2 OHMS in series it would be 8 OHMS... series is positive to negative. Are you using a crossover network?
Mar 05, 2010 | Kicker CVR12 Car Subwoofer
Whats the best way to hook up a 12 inch dual voice coil insignia subwoofer spkr to a 4 channel 650 rev boss amp
Well without seeing a spec sheet on the amp and not knowing your voice coil impedance I will assume the following. If the speaker is dual 4 ohm voice coil the in parallel it would present a 2 ohm impedance to the amp. If this amp is stable down to 2 ohms bridged then that would be the hookup of choice. If it is not stable to two ohms with one speaker it will be tough to get full performance out of your amp. You would have to series the voice coils which would then present an 8 ohm impedance to the amp. Just look at your amp's manual before making the decision. My suggestion would be to get another one of those subwoofers parallel the voice coils on each then wire the two subwoofers in series. This would give you a 4 ohm load which your amp is almost certain to be able to drive.
Jan 28, 2010 | Boss REV-650 Car Audio Amplifier
Try to install 3 12w3d6 subwoofers connecting 3 sub together to put them in box
You need to wire them according to the limitations of your amp you can pull a 1 ohm overall load just by connecting all of your coils in parallel- or you can get an overall load of 4 ohms by wiring each sub individually in a series configuration which will yield a 12 ohm load per sub -and then wire the 3 sets in parallel which will bring your ohms back down to 4. You can do a lot with that many coils it depends on your amp really-ideally a 1 ohm stable class d mono amp that is 1000-1500 watts rms would knock the **** outta those things JL is the good stuff.
Jan 16, 2010 | Jl Audio 12W3 Car Subwoofer
Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
I need instructions connecting my car subwoofers
Bridging your amplifier @ 4 ohm will yield the most power.... with the subwoofers you have.
You must wire them in Parallel.
Positive on both subwoofers to + on amplifier.
Negative on both subwoofers to - on amplifier.
The lowest impedence possible with 8 ohm woofers is 4 ohms.
Thank you for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 28, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
12" kicker l5
Series is +amp to +1, -1 to +2 , -2 to -amp . This way you have wired the two voice coils into one higher impedance voice coil.
Dec 11, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 4_2ohm_dvc_1ohm.gif
Dec 17, 2007 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
104 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
